Ana içeriğe geç
Dell Inspiron 13-5368 Audio Jack Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13-5368 Audio Jack Replacement, 3.5 mm Audio Jack: adım 1, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the 9 6mm screws securing the back plate of the laptop.
  2. Dell Inspiron 13-5368 Audio Jack Replacement: adım 2, 1 resimden 1.
    • Use a prying tool to remove the back plate.
  3. Dell Inspiron 13-5368 Audio Jack Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws holding the battery in place.
  4. Dell Inspiron 13-5368 Audio Jack Replacement: adım 4, 1 resimden 1.
    • Disconnect the cable connecting the battery to the motherboard, and then remove the battery.
  5. Dell Inspiron 13-5368 Audio Jack Replacement: adım 5, 2 resimden 1. Dell Inspiron 13-5368 Audio Jack Replacement: adım 5, 2 resimden 2.
    • Using the Phillips #0 screwdriver, unscrew the 4 heatsink screws.
    • Remove the heatsink assembly.
  6. Dell Inspiron 13-5368 Audio Jack Replacement: adım 6, 1 resimden 1.
    • Using the Phillips #0, unscrew two 3mm screws holding the fan in place and disconnect the cable connecting it to the motherboard. There is an adhesive tab holding the hard drive cable in place up against the fan; remove this as well.
  7. Dell Inspiron 13-5368 Audio Jack Replacement: adım 7, 3 resimden 1. Dell Inspiron 13-5368 Audio Jack Replacement: adım 7, 3 resimden 2. Dell Inspiron 13-5368 Audio Jack Replacement: adım 7, 3 resimden 3.
    • Disconnect the following cables that connect to the motherboard: the Touchscreen, Display, and the speaker cable.
  8. Dell Inspiron 13-5368 Audio Jack Replacement: adım 8, 3 resimden 1. Dell Inspiron 13-5368 Audio Jack Replacement: adım 8, 3 resimden 2. Dell Inspiron 13-5368 Audio Jack Replacement: adım 8, 3 resimden 3.
    • Disconnect the following cables that connect to the motherboard: hard drive cable and touchpad cable.
  9. Dell Inspiron 13-5368 Audio Jack Replacement: adım 9, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the three 2mm screws holding the motherboard in place. Once done, carefully lift the motherboard out.
  10. Dell Inspiron 13-5368 Audio Jack Replacement: adım 10, 1 resimden 1.
    • Flip the motherboard over and, using a soldering iron, apply heat to the 7 solder points of the audio jack. Carefully pull the audio jack out from below.
    • For more tips on soldering, please visit the How to Solder and Desolder Connections guide.
Sonuç
Ian Zahar
208 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S4-G4, Wilson Fall 2018 IUPUI, Team S4-G4, Wilson Fall 2018 üyesi
IUPUI-WILSON-F18S4G4
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 37
Her zaman: 1,976
