Ana içeriğe geç
Dell Inspiron 13-7347 Motherboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13-7347 Motherboard Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 13-7347 Motherboard Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 13-7347 Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • Flip the device over, so that the back is facing up.
    • Remove the ten, 7 mm, Phillips #1 screws on the back of your Dell Inspiron 13-7347.
    • Use the suction cup to lift off the back case.
  2. Dell Inspiron 13-7347 Motherboard Replacement: adım 2, 3 resimden 1. Dell Inspiron 13-7347 Motherboard Replacement: adım 2, 3 resimden 2. Dell Inspiron 13-7347 Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove the three 4 mm JIS #00 screws that secure the battery to the device.
  3. Dell Inspiron 13-7347 Motherboard Replacement: adım 3, 3 resimden 1. Dell Inspiron 13-7347 Motherboard Replacement: adım 3, 3 resimden 2. Dell Inspiron 13-7347 Motherboard Replacement: adım 3, 3 resimden 3.
    • Unplug the flat connector that is connected to the battery.
  4. Dell Inspiron 13-7347 Motherboard Replacement: adım 4, 3 resimden 1. Dell Inspiron 13-7347 Motherboard Replacement: adım 4, 3 resimden 2. Dell Inspiron 13-7347 Motherboard Replacement: adım 4, 3 resimden 3.
    • Lift the battery steadily from the device.
    • Tilt the battery upward while removing.
  5. Dell Inspiron 13-7347 Motherboard Replacement, Fan: adım 5, 2 resimden 1. Dell Inspiron 13-7347 Motherboard Replacement, Fan: adım 5, 2 resimden 2.
    • You should be able to identify the fan.
    • This is the 2.5 mm JIS #00 screw.
    • This is the 4 mm JIS #00 screw.
  6. Dell Inspiron 13-7347 Motherboard Replacement: adım 6, 2 resimden 1. Dell Inspiron 13-7347 Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the 2.5 mm JIS #00 screw.
    • Remove the 4 mm JIS #00 screw.
  7. Dell Inspiron 13-7347 Motherboard Replacement: adım 7, 2 resimden 1. Dell Inspiron 13-7347 Motherboard Replacement: adım 7, 2 resimden 2.
    • Detach the cable that connects the fan and the motherboard.
    • The cable is extremely fragile.
  8. Dell Inspiron 13-7347 Motherboard Replacement: adım 8, 2 resimden 1. Dell Inspiron 13-7347 Motherboard Replacement: adım 8, 2 resimden 2.
    • Detach the cord that connects the fan and the motherboard.
  9. Dell Inspiron 13-7347 Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove the fan.
  10. Dell Inspiron 13-7347 Motherboard Replacement, Hard Drive: adım 10, 2 resimden 1. Dell Inspiron 13-7347 Motherboard Replacement, Hard Drive: adım 10, 2 resimden 2.
    • Using a Phillips #0 screwdriver, loosen and remove the two 3.0 mm hard drive screws.
    • Lift the hard drive up and out of the device.
  11. Dell Inspiron 13-7347 Motherboard Replacement, Display Assembly: adım 11, 3 resimden 1. Dell Inspiron 13-7347 Motherboard Replacement, Display Assembly: adım 11, 3 resimden 2. Dell Inspiron 13-7347 Motherboard Replacement, Display Assembly: adım 11, 3 resimden 3.
    • Using a Phillips #0 screwdriver, remove the three 3.0 mm heat sink screws.
    • Remove the Heat Sink.
    • When reinstalling the heat sink, be sure to clean both contact surfaces with isopropyl alcohol and reapply thermal paste.
  12. Dell Inspiron 13-7347 Motherboard Replacement: adım 12, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the two 5.0 mm screws on the metal bracket.
    • Remove the metal bracket.
  13. Dell Inspiron 13-7347 Motherboard Replacement: adım 13, 1 resimden 1.
    • Loosen and reposition the display cable.
    • The display cable will not be removed. Do not attempt to remove the display cable.
  14. Dell Inspiron 13-7347 Motherboard Replacement: adım 14, 3 resimden 1. Dell Inspiron 13-7347 Motherboard Replacement: adım 14, 3 resimden 2. Dell Inspiron 13-7347 Motherboard Replacement: adım 14, 3 resimden 3.
    • Using a Phillips #0 screwdriver, remove the 5.0mm screw on the left display hinge bracket.
    • Using a Phillips #0 screwdriver, remove the two 5.0mm screws on the right display hinge bracket.
    • Lift and remove the display assembly.
  15. Dell Inspiron 13-7347 Motherboard Replacement, Motherboard: adım 15, 3 resimden 1. Dell Inspiron 13-7347 Motherboard Replacement, Motherboard: adım 15, 3 resimden 2. Dell Inspiron 13-7347 Motherboard Replacement, Motherboard: adım 15, 3 resimden 3.
    • Using a Phillips #0 screwdriver, remove the 5.0 mm DC jack screw.
    • Unplug and remove the DC jack.
  16. Dell Inspiron 13-7347 Motherboard Replacement: adım 16, 2 resimden 1. Dell Inspiron 13-7347 Motherboard Replacement: adım 16, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using your fingers or a pair of tweezers, unplug and loosen the display cable by pulling it straight out of its connector.
  17. Dell Inspiron 13-7347 Motherboard Replacement: adım 17, 1 resimden 1.
    • Using your fingers or a pair of tweezers, unplug the speaker cable by pulling it straight out of its connector.
  18. Dell Inspiron 13-7347 Motherboard Replacement: adım 18, 2 resimden 1. Dell Inspiron 13-7347 Motherboard Replacement: adım 18, 2 resimden 2.
    • Unplug and remove keyboard cable.
  19. Dell Inspiron 13-7347 Motherboard Replacement: adım 19, 3 resimden 1. Dell Inspiron 13-7347 Motherboard Replacement: adım 19, 3 resimden 2. Dell Inspiron 13-7347 Motherboard Replacement: adım 19, 3 resimden 3.
    • Using your fingers or a pair of tweezers, unplug the three motherboard cables by pulling them straight out of their connectors.
  20. Dell Inspiron 13-7347 Motherboard Replacement: adım 20, 2 resimden 1. Dell Inspiron 13-7347 Motherboard Replacement: adım 20, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove one 2.5mm motherboard screw.
    • Remove the motherboard.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 441
