Ana içeriğe geç
Dell Inspiron 14-5415 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14-5415 RAM Replacement, Back Cover: adım 1, 1 resimden 1.
    • Close the lid and turn the laptop over to access the back cover.
  2. Dell Inspiron 14-5415 RAM Replacement: adım 2, 1 resimden 1.
    • Remove the five 4 mm screws from the back of the laptop using a Phillips #0 screwdriver.
    • Loosen the two remaining captive screws using a Phillips #0 screwdriver.
    • Captive screws tend to have a slightly larger head than normal screws, so it is important to use the correct size screwdriver to avoid damaging the screw or the device.
  3. Dell Inspiron 14-5415 RAM Replacement, RAM: adım 3, 1 resimden 1.
    • To access the Dell Inspiron RAM, turn the device upside down.
    • The fan should be positioned In the top right hand corner of the device.
    • The Dell logo on the battery pack should be in an upright position when locating parts.
  4. Dell Inspiron 14-5415 RAM Replacement: adım 4, 3 resimden 1. Dell Inspiron 14-5415 RAM Replacement: adım 4, 3 resimden 2. Dell Inspiron 14-5415 RAM Replacement: adım 4, 3 resimden 3.
    • Raise the thin plastic tab that is covering the RAM.
    • Gently dislodge the metal hooks that are on both sides of the RAM by slightly pulling them apart.
    • The metal hooks are very thin, be sure not to bend them while dislodging them.
  5. Dell Inspiron 14-5415 RAM Replacement: adım 5, 2 resimden 1. Dell Inspiron 14-5415 RAM Replacement: adım 5, 2 resimden 2.
    • Gently pull on both sides the RAM to remove it.
    • Make sure to be gentle, as small scratches can permanently damage the RAM.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 30
Her zaman: 228
