Ana içeriğe geç
Dell Inspiron 15 3567 BIOS CMOS Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Remove Main Battery: adım 1, 2 resimden 1. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Remove Main Battery: adım 1, 2 resimden 2.
    • Push the battery-bay-release latch on the bottom of the laptop, sliding it to its unlocked position.
    • Remove the battery from the bay by pulling it upwards and at an angle.
  2. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Remove Plastic Base Cover Screw: adım 2, 1 resimden 1.
    • Remove the 2x5mm screw that attaches the optical disk drive to the laptop’s plastic base cover.
  3. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Remove Optical Disk Drive Assembly: adım 3, 3 resimden 1. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Remove Optical Disk Drive Assembly: adım 3, 3 resimden 2. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Remove Optical Disk Drive Assembly: adım 3, 3 resimden 3.
    • Using a flat-headed screwdriver, push the optical disk drive assembly to the left until it pops out of the side of the laptop.
    • Slide the optical disk drive assembly completely out of the base of the laptop.
  4. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Remove Optical Disk Drive Bracket: adım 4, 2 resimden 1. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Remove Optical Disk Drive Bracket: adım 4, 2 resimden 2.
    • Remove the 2x3mm optical disk drive screw from the optical disk drive bracket located on the right side of the optical disk drive assembly.
    • Remove the optical disk bracket from the optical disk drive assembly.
  5. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Loosen Keyboard: adım 5, 3 resimden 1. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Loosen Keyboard: adım 5, 3 resimden 2. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Loosen Keyboard: adım 5, 3 resimden 3.
    • Using a flat-headed screwdriver and the five tabs located at the top of the laptop’s keyboard, pry the laptop’s keyboard upwards, loosening the keyboard from the laptop’s palm-rest assembly.
    • Lift the keyboard off of the laptop's palm-rest assembly and place it upside down on top of the laptop's touch pad.
    • Do not completely remove the keyboard from the laptop because it is still attached to the system board.
  6. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Remove Keyboard: adım 6, 3 resimden 1. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Remove Keyboard: adım 6, 3 resimden 2. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Remove Keyboard: adım 6, 3 resimden 3.
    • Open the latch securing the keyboard cable by pulling it upwards with a flat-headed screwdriver and disconnect the keyboard cable from the connector located on the system board.
    • Following the same process, disconnect the optical drive cable from the connector located on the system board.
    • Completely remove the keyboard from the laptop.
  7. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Remove Metal Base Cover Screws: adım 7, 1 resimden 1.
    • Remove the five 2x5mm screws that secure the metal base cover to the palm-rest assembly.
  8. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Loosen Plastic Base Cover: adım 8, 2 resimden 1. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Loosen Plastic Base Cover: adım 8, 2 resimden 2.
    • Remove the two 2x5mm screws located in the battery bay area.
    • Remove the eight 5x8mm screws located on the laptop's plastic base cover.
    • Remove the three 2x2mm screws located in the optical disk drive area.
    • Be careful to keep each set of screws separate.
  9. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Remove Plastic Base Cover: adım 9, 2 resimden 1. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Remove Plastic Base Cover: adım 9, 2 resimden 2.
    • Using a flat-headed screw driver, pry the laptop’s plastic base cover off the palm-rest assembly and remove it from the laptop.
  10. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Remove CMOS Battery: adım 10, 1 resimden 1.
    • Using a flat-headed screwdriver, release the latch under the CMOS CR2032 battery and gently pop the CMOS CR2032 battery out of its plastic holder.
  11. Dell Inspiron 15 3567 BIOS CMOS Battery Replacement, Replace CMOS Battery: adım 11, 1 resimden 1.
    • Slide the new CMOS CR2032 battery back into its plastic holder.
Sonuç
William Harrison Daniel
193 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Why do we need to do Step 4, "Remove Optical Disk Drive Bracket" when the optical drive is already separated from the laptop and not connected to it at that point?
Patrick Benner - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 59
Her zaman: 1,249
