Giriş
In this guide, you will successfully learn how to replace the wireless card on a Dell Inspiron 15-5565. Please see this page to perform troubleshooting.
Neye ihtiyacın var
Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
Remove the single screw securing the wireless card bracket using a Phillips #00 screwdriver.
Slide the bracket to remove it.
Disconnect the two cables from the wireless card.
