Ana içeriğe geç
Dell Inspiron 15-7567 Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 15-7567 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off laptop before beginning.
    • Place the laptop upside down on a flat, stable surface.
  2. Dell Inspiron 15-7567 Battery Replacement: adım 2, 2 resimden 1. Dell Inspiron 15-7567 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
  3. Dell Inspiron 15-7567 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the panel from the sides and pull it out at an angle towards you.
  4. Dell Inspiron 15-7567 Battery Replacement: adım 4, 2 resimden 1. Dell Inspiron 15-7567 Battery Replacement: adım 4, 2 resimden 2.
    • Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
  5. Dell Inspiron 15-7567 Battery Replacement: adım 5, 2 resimden 1. Dell Inspiron 15-7567 Battery Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
    • Pinch the clips on the left and right side while pulling on the cord at the same time.
  6. Dell Inspiron 15-7567 Battery Replacement: adım 6, 1 resimden 1.
    • Pull the battery towards you.
    • Make sure to pull at an upward angle.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 44
Her zaman: 6,806
