Ana içeriğe geç
Dell Inspiron 1521 DVD Drive Replacement
Rogelio Ordonez
Rogelio Ordonez ve 4 diğer katkıda bulunanlar
En son January 28, 2014 tarihinde güncellendi
10 dakika
Kolay
İşlem Görüntüleri
Daha İyi Resimler Gerekli
This guide will show how to access your DVD drive.
Neye ihtiyacın var
Aletler
  1. Dell Inspiron 1521 DVD Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Rotate the laptop so its bottom is facing up.
  2. Dell Inspiron 1521 DVD Drive Replacement: adım 2, 3 resimden 1. Dell Inspiron 1521 DVD Drive Replacement: adım 2, 3 resimden 2. Dell Inspiron 1521 DVD Drive Replacement: adım 2, 3 resimden 3.
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. Dell Inspiron 1521 DVD Drive Replacement, DVD Drive: adım 3, 2 resimden 1. Dell Inspiron 1521 DVD Drive Replacement, DVD Drive: adım 3, 2 resimden 2.
    • Locate the 4 mm Phillips #1 screw next to the white padlock image that holds the DVD drive in place.
    • Remove this screw with a Phillips #1 screwdriver.
  4. Dell Inspiron 1521 DVD Drive Replacement: adım 4, 3 resimden 1. Dell Inspiron 1521 DVD Drive Replacement: adım 4, 3 resimden 2. Dell Inspiron 1521 DVD Drive Replacement: adım 4, 3 resimden 3.
    • Use a plastic opener tool to carefully pry the DVD drive out of its pocket on the side of the laptop.
    • Once sticking out, pull the DVD drive the rest of the way out with your hand.
Sonuç
Rogelio Ordonez
54 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-47, Forte Fall 2012 Cal Poly, Team 15-47, Forte Fall 2012 üyesi
CPSU-FORTE-F12S15G47
5 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 26
Her zaman: 1,044
