Ana içeriğe geç
Dell Inspiron 1525 Heat Sink Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1525 Heat Sink Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Heat Sink Replacement: adım 2, 2 resimden 1. Dell Inspiron 1525 Heat Sink Replacement: adım 2, 2 resimden 2.
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Heat Sink Replacement, Bottom Cover: adım 3, 2 resimden 1. Dell Inspiron 1525 Heat Sink Replacement, Bottom Cover: adım 3, 2 resimden 2.
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  4. Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: adım 4, 3 resimden 1. Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: adım 4, 3 resimden 2. Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: adım 4, 3 resimden 3.
    • Loosen the five #1 Phillips screws securing the heat sink and clean it with compressed air
    • These screws are attached to the heat sink assembly.
    • Gently lift the heat sink from side indicated in the picture.
    • The heat sink may feel like it is glued to the chips because of the thermal paste. Gently wiggle the heat sink back and forth to help break it free.
    • Be sure to thoroughly clean off the old thermal paste and apply new thermal paste before reinstalling the heat sink. Follow our thermal paste application guide for detailed instructions.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Is there any option to modify the heatsink for better cooling
manashpratim saikia - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 20
Her zaman: 7,926
