Ana içeriğe geç
Dell Inspiron 16-7610 Motherboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 16-7610 Motherboard Replacement, Back Case: adım 1, 2 resimden 1. Dell Inspiron 16-7610 Motherboard Replacement, Back Case: adım 1, 2 resimden 2.
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
    • Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
  2. Dell Inspiron 16-7610 Motherboard Replacement: adım 2, 1 resimden 1.
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
  3. Dell Inspiron 16-7610 Motherboard Replacement, Battery: adım 3, 3 resimden 1. Dell Inspiron 16-7610 Motherboard Replacement, Battery: adım 3, 3 resimden 2. Dell Inspiron 16-7610 Motherboard Replacement, Battery: adım 3, 3 resimden 3.
    • Use a Phillips #00 to remove the five screws securing the battery to the laptop.
    • Pull the bundled cable away from the connector in the same direction as the wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Use both hands to life the battery up and remove it from the laptop.
  4. Dell Inspiron 16-7610 Motherboard Replacement, Wi-Fi Card: adım 4, 2 resimden 1. Dell Inspiron 16-7610 Motherboard Replacement, Wi-Fi Card: adım 4, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the screw that secures the Wi-Fi card bracket to the system board.
    • Lift the Wi-Fi card bracket off of the Wi-Fi card.
  5. Dell Inspiron 16-7610 Motherboard Replacement: adım 5, 2 resimden 1. Dell Inspiron 16-7610 Motherboard Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to disconnect the coaxial cables from the Wi-Fi card.
    • Slide the Wi-Fi card from the slot to remove it from the device.
  6. Dell Inspiron 16-7610 Motherboard Replacement, RAM: adım 6, 3 resimden 1. Dell Inspiron 16-7610 Motherboard Replacement, RAM: adım 6, 3 resimden 2. Dell Inspiron 16-7610 Motherboard Replacement, RAM: adım 6, 3 resimden 3.
    • Flip the plastic cover over to reveal the RAM stick. Do not pull the plastic cover off.
    • Pull the two RAM retaining arms away from the center of the RAM stick.
    • The RAM stick should "pop" up slightly from its socket.
    • Pull the RAM stick out of the socket. Repeat for each of the RAM sticks you are replacing.
    • Align your new RAM sticks on to the sockets when installing them to prevent any damage to the pins below.
  7. Dell Inspiron 16-7610 Motherboard Replacement, Motherboard: adım 7, 1 resimden 1.
    • Double check that every component is removed from the motherboard.
    • Disconnect all the pin and ribbon cables from the motherboard.
    • Locate and remove all the screws that are holding the motherboard in place.
  8. Dell Inspiron 16-7610 Motherboard Replacement: adım 8, 3 resimden 1. Dell Inspiron 16-7610 Motherboard Replacement: adım 8, 3 resimden 2. Dell Inspiron 16-7610 Motherboard Replacement: adım 8, 3 resimden 3.
    • Remove the screws and cables connecting the fans to the motherboard.
    • Lift the fans off of the board to remove.
  9. Dell Inspiron 16-7610 Motherboard Replacement: adım 9, 2 resimden 1. Dell Inspiron 16-7610 Motherboard Replacement: adım 9, 2 resimden 2.
    • Use the Phillips #00 screwdriver to loosen the four screws from the heat sink.
    • Use both hands to gently lift the heatsink up.
    • Be mindful of the thermal paste on both the motherboard and the heatsink.
    • We recommend reapplying thermal paste on the heatsink before installing the new motherboard.
  10. Dell Inspiron 16-7610 Motherboard Replacement: adım 10, 2 resimden 1. Dell Inspiron 16-7610 Motherboard Replacement: adım 10, 2 resimden 2.
    • Use a spudger to pry up on each side of the press-fit connector, then lift the connector straight up to disconnect it from the motherboard.
  11. Dell Inspiron 16-7610 Motherboard Replacement: adım 11, 1 resimden 1.
    • Lift the motherboard out of the device.
Sonuç
Jerson Gomez
877 İtibar
3 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-3, Pee Spring 2023 Gateway, Team 1-3, Pee Spring 2023 üyesi
GCC-PEE-S23S1G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 49
Her zaman: 815
