Ana içeriğe geç
Dell Inspiron 3520 Optical Drive Replacement
Ian
Ian ve başka bir katkıda bulunan
En son June 11, 2015 tarihinde güncellendi
15 dakika
Kolay
This repair process includes the removal of small pieces from the computer, therefore you should have a place to store all the small removable screws. This will make the repair process quicker and easier.
Neye ihtiyacın var
Parçalar
Aletler
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Dell Inspiron 3520 Optical Drive Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 3520 Optical Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 Optical Drive Replacement: adım 2, 3 resimden 1. Dell Inspiron 3520 Optical Drive Replacement: adım 2, 3 resimden 2. Dell Inspiron 3520 Optical Drive Replacement: adım 2, 3 resimden 3.
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
  3. Dell Inspiron 3520 Optical Drive Replacement, Keyboard: adım 3, 2 resimden 1. Dell Inspiron 3520 Optical Drive Replacement, Keyboard: adım 3, 2 resimden 2.
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
  4. Dell Inspiron 3520 Optical Drive Replacement: adım 4, 1 resimden 1.
    • Slide the keyboard forward towards the screen to release the bottom tabs.
  5. Dell Inspiron 3520 Optical Drive Replacement: adım 5, 2 resimden 1. Dell Inspiron 3520 Optical Drive Replacement: adım 5, 2 resimden 2.
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
  6. Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: adım 6, 2 resimden 1. Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: adım 6, 2 resimden 2.
    • Locate and remove the 4mm Phillips #00 mounting screw.
  7. Dell Inspiron 3520 Optical Drive Replacement: adım 7, 2 resimden 1. Dell Inspiron 3520 Optical Drive Replacement: adım 7, 2 resimden 2.
    • Push the optical drive from the inside a little bit to dislodge it.
    • Grab the drive with your hand from the outside and slide it free.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Ian
1.557 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-2, Watkins Winter 2015 USF Tampa, Team 16-2, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S16G2
3 Üyeler
Bir Yorum
...screaming.....i love my dell 3520 it is awesome, it is still holding up.."hooray!!!!
Madeline Jones - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 24
Her zaman: 2,688
