Ana içeriğe geç
Dell Inspiron 3520 RAM Replacement
Ian
Ian ve başka bir katkıda bulunan
En son June 11, 2015 tarihinde güncellendi
10 dakika
Kolay
This repair process involves going into the computer, therefore,you will need to be gentle with electronic components. Also, consider working on this repair in a clean environment so no small pieces of the computer are lost.
Neye ihtiyacın var
Parçalar
Aletler
  • Spudger
    Spudger
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Dell Inspiron 3520 RAM Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 3520 RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 RAM Replacement: adım 2, 3 resimden 1. Dell Inspiron 3520 RAM Replacement: adım 2, 3 resimden 2. Dell Inspiron 3520 RAM Replacement: adım 2, 3 resimden 3.
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
  3. Dell Inspiron 3520 RAM Replacement, Keyboard: adım 3, 2 resimden 1. Dell Inspiron 3520 RAM Replacement, Keyboard: adım 3, 2 resimden 2.
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
  4. Dell Inspiron 3520 RAM Replacement: adım 4, 1 resimden 1.
    • Slide the keyboard forward towards the screen to release the bottom tabs.
  5. Dell Inspiron 3520 RAM Replacement: adım 5, 2 resimden 1. Dell Inspiron 3520 RAM Replacement: adım 5, 2 resimden 2.
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
  6. Dell Inspiron 3520 RAM Replacement, RAM: adım 6, 1 resimden 1.
    • Locate the RAM chip(s)
    • There are no RAM chips present in this photo.
  7. Dell Inspiron 3520 RAM Replacement: adım 7, 2 resimden 1. Dell Inspiron 3520 RAM Replacement: adım 7, 2 resimden 2.
    • There are two connecting pins for the lower chip.
    • There are two connecting pins for the upper chip.
    • Pull the pins away from the sides of the chip(s) to release it.
    • The chip(s) should slide away from the dock easily.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Ian
1.557 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-2, Watkins Winter 2015 USF Tampa, Team 16-2, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S16G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 28
Son 30 gün: 69
Her zaman: 32,636
