Ana içeriğe geç
Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement
Drew Cunningham
Drew Cunningham ve 6 diğer katkıda bulunanlar
En son March 4, 2025 tarihinde güncellendi
10 - 15 dakika
Orta
İşlem Görüntüleri
Adım Kırpıcı
Daha iyi giriş
Öğrenci İş Başında
The Peripheral Component Interconnect (PCI) slot is a built-in slot that allows the attachment of various hardware components on the motherboard of a computer. It can hold different types of cards:  network cards, modems, sound cards, disk controllers and other peripherals. As well as a Wi-Fi receiver or Bluetooth.
Neye ihtiyacın var
Aletler
  1. Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement, PCI Slot: Dial up modem: adım 1, 2 resimden 1. Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement, PCI Slot: Dial up modem: adım 1, 2 resimden 2.
    • Unscrew the two large screws in the back holding on the side panel.
    • Slide the panel backwards to remove it.
  2. Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: adım 2, 3 resimden 1. Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: adım 2, 3 resimden 2. Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: adım 2, 3 resimden 3.
    • The PCI slots are located at the bottom back of the computer.
    • Unscrew the screw to release the metal piece that holds the cards in place.
    • Remove metal piece.
  3. Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: adım 3, 2 resimden 1. Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: adım 3, 2 resimden 2.
    • Slide the card in the PCI slot up and out.
    • In this case, it is a dial up modem.
  4. Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: adım 4, 3 resimden 1. Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: adım 4, 3 resimden 2. Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: adım 4, 3 resimden 3.
    • Take the new card and slide it into the slot that you removed the old one out of.
    • Remember to replace the metal piece you removed earlier to secure the cards in place.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Drew Cunningham
656 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-1, Kish Spring 2015 UMass Dartmouth, Team 5-1, Kish Spring 2015 üyesi
UMASSD-KISH-S15S5G1
5 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 910
