Ana içeriğe geç
Dell Inspiron 530 Replacement of GPU
Neye ihtiyacın var
  1. Dell Inspiron 530 Replacement of GPU, GPU: adım 1, 1 resimden 1.
    • Remove the side panel, and and and screws that may be holding it in place.
  2. Dell Inspiron 530 Replacement of GPU: adım 2, 1 resimden 1.
    • Locate the GPU, which should be in the PCIe 16x slot below the fan.
    • Take the old GPU out and put the new GPU in its place.
    • Make sure that you have correctly grounded yourself and that you are using proper tools to reduce the risk of ESD and component destruction. Also make sure that the graphics card that you are using has enough voltage to be powered by your current power supply.
Sonuç
To reassemble your device, reattach any cables and screws that were disconnected and put the cover back on.
3 farklı kişi bu kılavuzu tamamladı.
bacon
277 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
En français on ne dit pas “Processeur graphique” mais “Carte Graphique” car on achète et on change toute la carte graphique.
Hyperion - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 52
Her zaman: 2,100
