Ana içeriğe geç
Dell Inspiron 531 Graphics Card Replacement
Neye ihtiyacın var
  1. Dell Inspiron 531 Graphics Card Replacement, Side Panel: adım 1, 2 resimden 1. Dell Inspiron 531 Graphics Card Replacement, Side Panel: adım 1, 2 resimden 2.
    • Place the desktop on its side. Make sure to place the computer on a soft but firm surface.
    • Locate and remove the two screws that secure the side panel to the desktop:
    • Two 1/4" Phillips/slotted combination screws.
  2. Dell Inspiron 531 Graphics Card Replacement: adım 2, 1 resimden 1.
    • Slide the side panel towards the back of the desktop in order to remove it.
  3. Dell Inspiron 531 Graphics Card Replacement, Locating the Graphics Card: adım 3, 2 resimden 1. Dell Inspiron 531 Graphics Card Replacement, Locating the Graphics Card: adım 3, 2 resimden 2.
    • The graphics card is attached to the back of the desktop.
    • The graphics card is located below the three fans.
  4. Dell Inspiron 531 Graphics Card Replacement, Support Bracket: adım 4, 1 resimden 1.
    • Remove the screw that secures the support bracket:
    • One 1/4" Phillips screw
  5. Dell Inspiron 531 Graphics Card Replacement: adım 5, 2 resimden 1. Dell Inspiron 531 Graphics Card Replacement: adım 5, 2 resimden 2.
    • Remove the support bracket by lifting up and out.
    • There are tabs that hold the bracket in place, therefor lifting up is an important detail.
  6. Dell Inspiron 531 Graphics Card Replacement, Removing the Graphics Card: adım 6, 2 resimden 1. Dell Inspiron 531 Graphics Card Replacement, Removing the Graphics Card: adım 6, 2 resimden 2.
    • Locate the push tab that locks the graphics card into place.
    • Push the tab away from the graphics card and towards the fan.
    • Hold the tab in this position through step 7.
  7. Dell Inspiron 531 Graphics Card Replacement: adım 7, 2 resimden 1. Dell Inspiron 531 Graphics Card Replacement: adım 7, 2 resimden 2.
    • Keep the tab pushed away from the graphics card (see Step 6).
    • Gently lift the graphics card up and out of the desktop.
Sonuç
Scott Havard
50.439 İtibar
31 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 1,432
