Ana içeriğe geç
Dell Inspiron 7000 2 in 1 Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 7000 2 in 1 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Flip your Dell Inspiron 7000 2 in 1 laptop upside down to get started. Find the locations of all the 10 screws.
    • Remember to turn the laptop off before you begin the repair.
  2. Dell Inspiron 7000 2 in 1 Battery Replacement: adım 2, 1 resimden 1.
    • Using your Phillips #00 screwdriver, remove the ten 7.00 mm screws at the bottom of the laptop.
  3. Dell Inspiron 7000 2 in 1 Battery Replacement: adım 3, 3 resimden 1. Dell Inspiron 7000 2 in 1 Battery Replacement: adım 3, 3 resimden 2. Dell Inspiron 7000 2 in 1 Battery Replacement: adım 3, 3 resimden 3.
    • Insert the spudger in the gap between the bottom cover and the frame. Then, use it as a wedge and work your way around the perimeter. This will pop open the bottom cover of the laptop.
  4. Dell Inspiron 7000 2 in 1 Battery Replacement: adım 4, 1 resimden 1.
    • Find the battery located at the bottom right corner of the laptop.
  5. Dell Inspiron 7000 2 in 1 Battery Replacement: adım 5, 1 resimden 1.
    • Now remove the four 4.0 mm Phillips #00 screws located at each corner of the battery.
  6. Dell Inspiron 7000 2 in 1 Battery Replacement: adım 6, 1 resimden 1.
    • Remove the battery pin that is connecting the motherboard to the battery by pulling out the pin gently.
    • Remember to safely recycle your old laptop battery.
  7. Dell Inspiron 7000 2 in 1 Battery Replacement: adım 7, 1 resimden 1.
    • Reinsert the battery pin into the new battery and place it back into its position.
  8. Dell Inspiron 7000 2 in 1 Battery Replacement: adım 8, 1 resimden 1.
    • Screw the four 4.0 mm Phillips #00 head screws for the battery back into place to make sure the battery is held on securely.
  9. Dell Inspiron 7000 2 in 1 Battery Replacement: adım 9, 1 resimden 1.
    • Place the cover back onto the laptop and press down on all corners and sides.
    • Make sure to listen for a click to ensure the cover is properly secured.
  10. Dell Inspiron 7000 2 in 1 Battery Replacement: adım 10, 1 resimden 1.
    • Use the Phillips #00 screwdriver to replace the ten 7.00 mm screws on the back cover.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Neelay Patel
255 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 42
Son 30 gün: 138
Her zaman: 5,894
