Giriş
If your 700m is prone to overheating, a new fan and some upgraded thermal paste may be just the ticket. You can also use this guide to access the fan for cleaning.
Neye ihtiyacın var
Before you begin, make sure the 700m is powered off.
Unplug the power cable.
Flip the 700m over and remove the battery.
Slide the battery release switch toward the center of the 700m, and then pull the battery free from the back.
Remove the three Phillips screws securing the hard drive cover.
Remove the hard drive cover and set it aside.
Remove the two Phillips screws securing the wi-fi cover.
Remove the wi-fi cover and set it aside.
Open the display and lay it down flat.
Beginning from the left side, use the flat end of a spudger to gently pry up the plastic trim that runs along the top of the keyboard. Remove the trim.
Identify the LCD cable, which connects to the top left side of the motherboard.
To disconnect the LCD cable, grab the pull tab on the top of the connector and pull it straight up from the motherboard.
It may be helpful to use a spudger or small flathead screwdriver for extra leverage.
Remove the two Phillips screws securing the inner RAM cover.
Tilt the right side of the RAM cover up at an angle and remove it.
Two clips secure the RAM module in place, one on either side. Using your fingers, spread the clips away from the RAM module.
Lift the RAM module to an angle of about 30 degrees and slide it out.
Beginning from the top left, use your fingers to separate the upper case from the 700m by pulling it straight up.
Remove the upper case.
Remove the two Phillips screws from the top right edge of the motherboard.
Flip the motherboard over and lay it down flat.
Disconnect the fan wire from the motherboard by pulling the connector straight up.
Now use our guide on How to Apply Thermal Paste to clean your heat sink and add some spicy hot thermal paste!
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
A very well detailed instruction , very well presented, easy to follow and step by step pictures reference for the amateur handy husband . Thanks for the acquired knowledge you have given.
