Giriş
This guide will show you how to remove the lower case and replace it with a new one.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Remove the battery from the bottom of the laptop.
Please click on the following link for further instruction on how to remove the battery. Dell Inspiron 9100 Battery Replacement
Insert a spludger into the notch at the far left side of the top blue panel and pry hinge cover off.
Note: You may need to pry the other side off by inserting the spludger between the hinge and the top cover.
Remove the screws at the top of the keyboard as indicated indicated.
You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
The keyboard should be easily removable at this point.
Flip the laptop over and remove the indicated screws.
Flip the laptop back over.
Find the two places where the display module is attached to the base of the computer.
