Ana içeriğe geç
Dell Inspiron N4010 Hard Disk Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron N4010 Hard Disk Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is not plugged into any wall outlets or the charger
    • Unlock the battery by sliding the right-hand switch to the right.
  2. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 2, 2 resimden 1. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 2, 2 resimden 2.
    • While holding the left-hand switch to the left position, pull the battery away from the laptop.
  3. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 3, 1 resimden 1.
    • The battery is now fully removed and the laptop will not power on without it.
  4. Dell Inspiron N4010 Hard Disk Drive Replacement, Keyboard: adım 4, 3 resimden 1. Dell Inspiron N4010 Hard Disk Drive Replacement, Keyboard: adım 4, 3 resimden 2. Dell Inspiron N4010 Hard Disk Drive Replacement, Keyboard: adım 4, 3 resimden 3.
    • Using the #0 Philips head, unscrew the indicated screw.
    • Carefully pull the RAM cover up and away.
  5. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 5, 1 resimden 1.
    • Unscrew the indicated 5.7mm screw beneath the RAM Cover.
    There Is one More screw that needs to be removed!!!
    Guillermo Zepeda - Yanıt
    • Remove another screw above the battery release tab
  6. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 7, 2 resimden 1. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 7, 2 resimden 2.
    • Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
    • Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
  7. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 8, 2 resimden 1. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 8, 2 resimden 2.
    • Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
    • Be careful not to put stress on the ribbon cable below.
  8. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 9, 2 resimden 1. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 9, 2 resimden 2.
    • Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
    • The keyboard is now completely disconnected.
  9. Dell Inspiron N4010 Hard Disk Drive Replacement, Palm Rest Assembly: adım 10, 2 resimden 1. Dell Inspiron N4010 Hard Disk Drive Replacement, Palm Rest Assembly: adım 10, 2 resimden 2.
    • Remove the indicated 5.7mm screws.
    • Remove the smaller 3mm screws from underneath the battery compartment.
    On the one I worked on there where 3 screws above the disk drive which caused the shroud to break. Make use to remove the disk drive and take out the screws before proceeding to the next step
    Alexander Whitney - Yanıt
  10. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 11, 2 resimden 1. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 11, 2 resimden 2.
    • With a plastic spudger, pry away the silver top cover from the black casing.
    • Move the tool to the right and left along the seams to fully disconnect the cover.
  11. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 12, 1 resimden 1.
    • Disconnect the indicated ribbon cables underneath where the keyboard sits.
  12. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 13, 1 resimden 1.
    • Lift the cover upwards and away from the body of the laptop, after removing the optical drive and unscrewing the three screws on the right.
    My same product does not have an open top because there are three screws in the ODD….ㅠㅠ
    김옥현 - Yanıt
  13. Dell Inspiron N4010 Hard Disk Drive Replacement, Fan: adım 14, 2 resimden 1. Dell Inspiron N4010 Hard Disk Drive Replacement, Fan: adım 14, 2 resimden 2.
    • Peel back the yellow tape to expose the ribbon connector.
    • Unplug the ribbon cable from the motherboard.
  14. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 15, 1 resimden 1.
    • Unplug the 3-wire connector from the motherboard.
  15. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 16, 1 resimden 1.
    • Unscrew the indicated 5.6mm screws with the #0 Phillips Head Screwdriver.
  16. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 17, 1 resimden 1.
    • Remove the fan from the device.
    Aluminum flux cable isn’t attached to fan assembly
    Daniel Sledge - Yanıt
    On bottom right to remove the driver gently slide the entire assembly to the right it will come out in one piece
  17. Dell Inspiron N4010 Hard Disk Drive Replacement, Motherboard: adım 18, 2 resimden 1. Dell Inspiron N4010 Hard Disk Drive Replacement, Motherboard: adım 18, 2 resimden 2.
    • Unscrew the two screws on the right hand speaker with the #0 Phillips Head.
    • Unplug the speaker connector from the motherboard.
  18. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 19, 1 resimden 1.
    • Reaching under the daughter board, disconnect the connector.
    • It will be under the board in the area indicated.
  19. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 20, 1 resimden 1.
    • Unscrew the indicated 5.6mm screws with a Phillips #0 screwdriver.
    Incorrect screw removal info. Under and to the right of B3 no screw until further assembly.
    derek hale - Yanıt
    The screws are numbered B1-B9 on the motherboard. There are three along the front edge not marked in this photo. The DVD drive screw is marked in this photo but it was removed previously.
    Wayne Sander - Yanıt
  20. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 21, 1 resimden 1.
    • The motherboard can now be removed by pulling upwards, tilting it to the left of the laptop until the connectors clear the body of the laptop.
  21. Dell Inspiron N4010 Hard Disk Drive Replacement, Hard Disk Drive: adım 22, 1 resimden 1.
    • Unscrew the 6 Phillips head screws holding the hard drive to the motherboard with the #0 driver head.
  22. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 23, 2 resimden 1. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 23, 2 resimden 2.
    • Slide the hard drive towards the center of the motherboard.
    • The hard drive should come away from the motherboard.
  23. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 24, 1 resimden 1.
    • Undo the 2 screws with the #0 Phillips head driver on either side of the hard drive assembly.
  24. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 25, 2 resimden 1. Dell Inspiron N4010 Hard Disk Drive Replacement: adım 25, 2 resimden 2.
    • Slide the assembly off of the hard drive.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Jonathan Sellier
952 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G5, Boczar Fall 2017 USF Tampa, Team S13-G5, Boczar Fall 2017 üyesi
USFT-BOCZAR-F17S13G5
5 Üyeler
9 adet Kılavuz yazıldı
7Kılavuz Yorumları
I hope somebody at Dell lost their job over this design.
Jason Northrup - Yanıt
hahaha i agree
Robert G -
The N4010 is definitely a beautiful-looking set, but it’s sure a tough nut to crack when it’s time to repair something inside it, lol :-D
Terry McKean -
A bunch of screws not listed have to be removed also they are in proximity of the cmos battery I imagine someone will damage their machine following this NOT GOOD! I signed up just to post this! Look for screws with the LETTER B they need removing before the board can come out! ifixit should screen their submissions better
ptooti - Yanıt
In step 20 we remove the screws
Jonathan Sellier -
I have the blue top/black bottom/silver keyboard-bezel N4010…. it’s defintely beautiful to my eyes, both in cabinet design and bright and clear picture on the display. Changing the 500 gig hard drive is exactly what I need to do to it. Thanks for sharing this tutorial, Jonathan Sellier. I was wondering what kind of connectors the HD had, and I see from the last photo that you posted in the series above that it’s a SATA connection. Now I know what to order for a replacement. Thanks again. :-)
Terry McKean - Yanıt
This was a fantastic guide and I can't thank you enough. One thing to note when reassembling is to make sure the daughterboard connector is fully seated before putting all of those screws back in. I found this one out the hard way because I wasn't paying enough attention to what I was doing.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 38
Her zaman: 7,430
