Ana içeriğe geç
Dell Inspiron N4010 Hard Drive Replacement
Terrence15
Terrence15 ve 2 diğer katkıda bulunanlar
En son November 15, 2019 tarihinde güncellendi
4 - 15 dakika
Kolay
Topluluk-Katkılı Kılavuz
In this guide, we will be showing you how to remove and replace the Hard Drive.
Neye ihtiyacın var
  1. Dell Inspiron N4010 Hard Drive Replacement, Remove the Screws: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard-drive assembly to the system board.
  2. Dell Inspiron N4010 Hard Drive Replacement, Sliding the Hard-Drive Assembly: adım 2, 1 resimden 1.
    • Slide the hard-drive assembly to disconnect it from the connector on the system board.
  3. Dell Inspiron N4010 Hard Drive Replacement, Lifting the Hard Drive Assembly: adım 3, 1 resimden 1.
    • Lift the hard-drive assembly away from the system board.
  4. Dell Inspiron N4010 Hard Drive Replacement, Remove the Screws: adım 4, 1 resimden 1.
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron N4010 Hard Drive Replacement, Lifting the Hard-Drive Bracket: adım 5, 1 resimden 1.
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron N4010 Hard Drive Replacement, Align the Screw Holes: adım 6, 1 resimden 1.
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive and replace the four screws.
  7. Dell Inspiron N4010 Hard Drive Replacement, Sliding the Hard-Drive Assembly: adım 7, 1 resimden 1.
    • Slide and push the hard-drive assembly to connect it to connector on the system board.
  8. Dell Inspiron N4010 Hard Drive Replacement, Replace the Screws: adım 8, 1 resimden 1.
    • Replace the two screws that secure the hard-drive assembly to the system board.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Terrence15
79.585 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 923
