Ana içeriğe geç
Dell Inspiron n5050 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron n5050 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Flip your laptop over to view the bottom and locate the two locks.
  2. Dell Inspiron n5050 RAM Replacement: adım 2, 1 resimden 1.
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron n5050 RAM Replacement: adım 3, 2 resimden 1. Dell Inspiron n5050 RAM Replacement: adım 3, 2 resimden 2.
    • Pull battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron n5050 RAM Replacement, Keyboard: adım 4, 2 resimden 1. Dell Inspiron n5050 RAM Replacement, Keyboard: adım 4, 2 resimden 2.
    • Flip the laptop right side up. Open the laptop.
    • Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • After the first tab is released, gently lift up on the keyboard so it doesn't lock again. Finish the other three tabs while gently lifting up on the keyboard. The keyboard will hinge up along the bottom.
  5. Dell Inspiron n5050 RAM Replacement: adım 5, 3 resimden 1. Dell Inspiron n5050 RAM Replacement: adım 5, 3 resimden 2. Dell Inspiron n5050 RAM Replacement: adım 5, 3 resimden 3.
    • Gently flip the data cable latch away from the data cable with flat side of spudger.
    • Lift the cable up and out.
    • When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area. When these are in place the cable is properly inserted.
    • For removing the optical drive you don't need to disconnect the keyboard ribbon cable.
    What do I do is i broke the cable retainer wings and the black thing?
    Wezley Joao Ferreira - Yanıt
    If the connector on the motherboard is still attached and only the clip is broken you can try and find a new clip, or perhaps tape the keyboard in place with electrical tape.
    Tyler - Yanıt
    I didn’t need to disconnect and remove the cable. I simply set the keyboard gently to the side. This gave me full access to the two RAM module slots for replacement. Hopefully this will make the procedure easier.
    Clemmitt Sigler - Yanıt
  6. Dell Inspiron n5050 RAM Replacement, RAM: adım 6, 3 resimden 1. Dell Inspiron n5050 RAM Replacement, RAM: adım 6, 3 resimden 2. Dell Inspiron n5050 RAM Replacement, RAM: adım 6, 3 resimden 3.
    • Locate RAM
    • Push outwards on both retaining clips, the RAM will pop up slightly when it is free from the clips.
  7. Dell Inspiron n5050 RAM Replacement: adım 7, 1 resimden 1.
    • The RAM will pop up, and then you can slide it out at the same angle it is at.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Tyler
5.031 İtibar
16 adet Kılavuz yazıldı
Ekip
TechForce TechForce üyesi
Business
2 Üyeler
29 adet Kılavuz yazıldı
1Rehber Yorum
Dell Inspiron 15 - M5040 N5040 N5050 disassembly
https://youtu.be/3c5P0pJgckg
mohamed - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 10,438
