Ana içeriğe geç
Dell Latitude 7420 Display Replacement
nuredinroba
nuredinroba ve 3 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
25 - 45 dakika
Orta
Many issues with displays, such as black screens, are software based and can be resolved by changing configurations or settings. However, if the issues are not resolved, or the display is physically damaged, it might need to be replaced.
This tutorial will guide you through replacing the display of a Dell Latitude 7420.
Before starting, please ensure the device is turned off and disconnected from any adaptors or charging cables.
Likewise, use an anti-static band or mat when opening computers or handling components.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Dell Latitude 7420 Display Replacement, Back Case: adım 1, 3 resimden 1. Dell Latitude 7420 Display Replacement, Back Case: adım 1, 3 resimden 2. Dell Latitude 7420 Display Replacement, Back Case: adım 1, 3 resimden 3.
    • Remove the eight, 7 mm screws from the back case using a Phillips #0 screwdriver.
    • Use an opening pick or opening tool and work your way around the periphery of the base cover to separate it from the chassis.
  2. Dell Latitude 7420 Display Replacement, Display: adım 2, 3 resimden 1. Dell Latitude 7420 Display Replacement, Display: adım 2, 3 resimden 2. Dell Latitude 7420 Display Replacement, Display: adım 2, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the three, 2 mm screws fastening the cable covers.
    • Remove both cable covers.
  3. Dell Latitude 7420 Display Replacement: adım 3, 2 resimden 1. Dell Latitude 7420 Display Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to detach the coaxial cables from the Wi-Fi card.
    • Disconnect the remaining cables connecting the display assembly to the board.
  4. Dell Latitude 7420 Display Replacement: adım 4, 3 resimden 1. Dell Latitude 7420 Display Replacement: adım 4, 3 resimden 2. Dell Latitude 7420 Display Replacement: adım 4, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the four 4 mm screws securing the display hinges.
    • There are two screws to remove from each hinge.
    • Lift the base to pull the display assembly free.
  5. Dell Latitude 7420 Display Replacement: adım 5, 1 resimden 1.
    • Separate the display assembly from the base of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
nuredinroba
209 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team 1-2, Pee Spring 2023 Gateway, Team 1-2, Pee Spring 2023 üyesi
GCC-PEE-S23S1G2
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 14
Son 30 gün: 108
Her zaman: 1,873
