Ana içeriğe geç
Dell Latitude 9410 2-in-1 SSD Replacement
Jessica Stephens
Jessica Stephens ve 7 diğer katkıda bulunanlar
En son January 3, 2024 tarihinde güncellendi
10 - 20 dakika
Orta
If you're finding many corrupted files or data, software incompatibility, hard drive errors, or an overall faulty SSD, then use this guide to replace the solid-state drive (SSD) of the Dell Latitude 9410 2-in-1. This guide should fix most file and incompatibility related issues on your laptop.
although, be sure to check the troubleshooting page before moving forward with replacement in case your problem is unrelated.
Neye ihtiyacın var
Tamir Setleri
Bu kitler, bu kılavuzu tamamlamak için gereken tüm parçaları ve araçları içerir.
Parçalar
Aletler
Daha fazlasını göster…
  1. Dell Latitude 9410 2-in-1 SSD Replacement, Base Panel: adım 1, 1 resimden 1.
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 SSD Replacement: adım 2, 2 resimden 1. Dell Latitude 9410 2-in-1 SSD Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 SSD Replacement: adım 3, 3 resimden 1. Dell Latitude 9410 2-in-1 SSD Replacement: adım 3, 3 resimden 2. Dell Latitude 9410 2-in-1 SSD Replacement: adım 3, 3 resimden 3.
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 SSD Replacement, SSD: adım 4, 3 resimden 1. Dell Latitude 9410 2-in-1 SSD Replacement, SSD: adım 4, 3 resimden 2. Dell Latitude 9410 2-in-1 SSD Replacement, SSD: adım 4, 3 resimden 3.
    • Carefully peel back and remove the black tape around the top left corner of the motherboard.
  5. Dell Latitude 9410 2-in-1 SSD Replacement: adım 5, 3 resimden 1. Dell Latitude 9410 2-in-1 SSD Replacement: adım 5, 3 resimden 2. Dell Latitude 9410 2-in-1 SSD Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the 2 mm screw, loosening the bracket that covers the SSD.
    • Carefully lift the off the bracket.
    • The bracket is attached to the laptop and cannot be removed completely.
  6. Dell Latitude 9410 2-in-1 SSD Replacement: adım 6, 3 resimden 1. Dell Latitude 9410 2-in-1 SSD Replacement: adım 6, 3 resimden 2. Dell Latitude 9410 2-in-1 SSD Replacement: adım 6, 3 resimden 3.
    • Grip the SSD and pull directly backward until the SSD releases from its port.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 34
Her zaman: 1,275
