Ana içeriğe geç
Dell Latitude E4310 RAM Replacement
Jordan Jones
Jordan Jones ve başka bir katkıda bulunan
En son June 14, 2018 tarihinde güncellendi
2 dakika
Kolay
If your laptop is experiencing slow boot times, poor performance, display issues, or won't boot at all, it may be time to replace the RAM, also referred to as the memory.
To replace the RAM on the Dell Latitude E4310, follow this guide.
Neye ihtiyacın var
Aletler
  1. Dell Latitude E4310 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Power down the laptop and remove all power cords.
  2. Dell Latitude E4310 RAM Replacement: adım 2, 2 resimden 1. Dell Latitude E4310 RAM Replacement: adım 2, 2 resimden 2.
    • Push in the battery release button with your thumb.
    • Pull up on the battery to remove.
  3. Dell Latitude E4310 RAM Replacement, Memory Door: adım 3, 2 resimden 1. Dell Latitude E4310 RAM Replacement, Memory Door: adım 3, 2 resimden 2.
    • Unscrew the two 4mm Phillips #1 screws.
  4. Dell Latitude E4310 RAM Replacement: adım 4, 2 resimden 1. Dell Latitude E4310 RAM Replacement: adım 4, 2 resimden 2.
    • Lift up the panel with your finger.
    • The screws are clipped to the panel and will remain attached.
  5. Dell Latitude E4310 RAM Replacement, RAM: adım 5, 2 resimden 1. Dell Latitude E4310 RAM Replacement, RAM: adım 5, 2 resimden 2.
    • Pry the two metal clips away from the RAM module until the module pops out of place.
  6. Dell Latitude E4310 RAM Replacement: adım 6, 2 resimden 1. Dell Latitude E4310 RAM Replacement: adım 6, 2 resimden 2.
    • Slide the RAM backwards out of its socket to remove.
  7. Dell Latitude E4310 RAM Replacement: adım 7, 2 resimden 1. Dell Latitude E4310 RAM Replacement: adım 7, 2 resimden 2.
    • Repeat steps 1 and 2 to remove the second RAM module.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 40
Her zaman: 1,250
