Ana içeriğe geç
Dell Latitude E6330 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Latitude E6330 Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. Dell Latitude E6330 Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Start by flipping the laptop over and removing the two, deeply recessed, 2.5mm x 5mm screws from the bottom face of the laptop.
  2. Dell Latitude E6330 Keyboard Replacement: adım 2, 3 resimden 1. Dell Latitude E6330 Keyboard Replacement: adım 2, 3 resimden 2. Dell Latitude E6330 Keyboard Replacement: adım 2, 3 resimden 3.
    • Grab a plastic spunger and slowly pop out the keyboard bezel from around the keyboard.
  3. Dell Latitude E6330 Keyboard Replacement: adım 3, 1 resimden 1.
    • Locate and remove the remaining three 2mm x 3mm screws connecting the keyboard to the frame. (One is located just left of the left mouse button and the remaining two are just right of the right mouse button).
  4. Dell Latitude E6330 Keyboard Replacement: adım 4, 3 resimden 1. Dell Latitude E6330 Keyboard Replacement: adım 4, 3 resimden 2. Dell Latitude E6330 Keyboard Replacement: adım 4, 3 resimden 3.
    • At this time you should be able to gently lift the keyboard off of the frame and expose a ribbon cable connecting it to the motherboard. Flip up the clip holding the ribbon in place and remove the faulty keyboard.
    • When connecting the new ribbon cable make sure you gently slide it into its slot before locking the latch back down to ensure it is properly connected.
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 farklı kişi bu kılavuzu tamamladı.
Brett Murray
399 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G3, Simcock Spring 2019 UMass Dartmouth, Team S2-G3, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S2G3
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
That's the way to do it!
goran ninkovic - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 29
Her zaman: 1,097
