Ana içeriğe geç
Dell Latitude E6400 Hard Drive Replacement
Neye ihtiyacın var
    • First, turn off your laptop and disconnect any external adapter.
  1. Dell Latitude E6400 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Release the latch or latches connected to the battery that hold it in place.
    Oops... I think steps 5-6-7 come before steps 3 and 4... But generally good instructions! Thanks.
    Fro Noho - Yanıt
  2. Dell Latitude E6400 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Remove the old battery from its storage bay.
    • Plug in the external AC adapter to fully charge the new battery.
  3. Dell Latitude E6400 Hard Drive Replacement, Remove the hard drive: adım 5, 1 resimden 1.
    • After removing the battery, locate and remove the two M3 x 3-mm screws securing the hard drive to the base assembly. Then, slide the hard drive from the base assembly.
  4. Dell Latitude E6400 Hard Drive Replacement, Remove the hard drive bezel: adım 6, 1 resimden 1.
    • Next, remove the M3 x 3-mm screw on the hard drive bezel and remove the hard drive bezel. NOTE: Be mindful not to touch the components of the drive. Doing so could damage the drive.
Sonuç
With your replacement hard drive, reassemble your device by performing the instructions above in reverse order.
Aaron Thomas
1.224 İtibar
10 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
2 Yorum
Easy hard drive replacement!
Jeffrey P - Yanıt
Buenas tardes mi dell e6400 al reproducir video o música de escucha con disco rayado y el video se pausa. Me podrían apoyar para su reparación
Arbey Gatica Sambrano - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 47
Her zaman: 1,587
