Ana içeriğe geç
Dell Latitude E6400 WiFi Card Replacement
Neye ihtiyacın var
  1. Dell Latitude E6400 WiFi Card Replacement, WiFi Card: adım 1, 2 resimden 1. Dell Latitude E6400 WiFi Card Replacement, WiFi Card: adım 1, 2 resimden 2.
    • Simultaneously slide the battery latches (outlined by the red box) to the dock connector in the middle.
    • This will release the battery. Just slide the battery away from the computer.
    • Open up the computer and press and hold the power button for 5 seconds. This drains any power left inside the computer.
    • This is important, as if electricity remains in the notebook, it can shock you and damage the logic board.
  2. Dell Latitude E6400 WiFi Card Replacement: adım 2, 2 resimden 1. Dell Latitude E6400 WiFi Card Replacement: adım 2, 2 resimden 2.
    • Loosen the center screw with a philips screw driver. This is the only screw that needs to be loosened.
    • It can't be removed as it is captive the the bottom plate.
    • Now slide the plate away from the dock connector.
  3. Dell Latitude E6400 WiFi Card Replacement: adım 3, 2 resimden 1. Dell Latitude E6400 WiFi Card Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool or a spudger to remove the antennas.
    • I use my fingers, but the picture shows and iPod opening tool because most adults have bigger fingers.
    • I'm 14, so my fingers are small enough.
    • Some E6400 models have a card with three connections-a gray wire in the middle-marked appropriately.
  4. Dell Latitude E6400 WiFi Card Replacement: adım 4, 1 resimden 1.
    • remove the one and only philips screw securing the WiFi card in place.
  5. Dell Latitude E6400 WiFi Card Replacement: adım 5, 2 resimden 1. Dell Latitude E6400 WiFi Card Replacement: adım 5, 2 resimden 2.
    • The card should instantly pop to an angle less than 45 degrees once the screw is removed.
    • Now simply pull the card strait away from the slot.
    • Install a new card by sliding it in the direction of the arrow and pressing firmly down until it clicks.
  6. Dell Latitude E6400 WiFi Card Replacement: adım 6, 2 resimden 1. Dell Latitude E6400 WiFi Card Replacement: adım 6, 2 resimden 2.
    • Slide the bottom plate on.
    • Slide it to the rear of the notebook. (battery compartment)
    • Tighten the screw.
    • Do not over-tighten. Doing so will strip the screw.
  7. Dell Latitude E6400 WiFi Card Replacement: adım 7, 2 resimden 1. Dell Latitude E6400 WiFi Card Replacement: adım 7, 2 resimden 2.
    • Slide the battery in until it clicks.
    • Press the power button.
    • AND it works.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Nicholas Ouimet
3.590 İtibar
11 adet Kılavuz yazıldı
1Rehber Yorum
Why is your soundcloud linked as the wifi card site. It is really not appropriate considering how great of a job you did with the instructions for this repair.
Sean Brewer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 28,673
