Ana içeriğe geç
Dell Precision 3541 Battery Replacement
Neye ihtiyacın var
  1. Dell Precision 3541 Battery Replacement, Battery: adım 1, 3 resimden 1. Dell Precision 3541 Battery Replacement, Battery: adım 1, 3 resimden 2. Dell Precision 3541 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • The first step for battery replacement is to remove the base cover which is the bottom panel of the device. You will find a total of eight small screws, three on each side, and two in the middle of the panel. Once all screws are removed, it may be helpful to use a flat, pointy tool such as a paint key, to pop the panel off of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Precision 3541 Battery Replacement: adım 2, 2 resimden 1. Dell Precision 3541 Battery Replacement: adım 2, 2 resimden 2.
    • Once looking at the interior of the underbody, you should find a rectangular encasement panel in the bottom right corner of the device. This component is the battery. On the battery, you will find one screw on the right side and two on the top. Unscrew all three carefully, putting them in a safe holding place.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Precision 3541 Battery Replacement: adım 3, 3 resimden 1. Dell Precision 3541 Battery Replacement: adım 3, 3 resimden 2. Dell Precision 3541 Battery Replacement: adım 3, 3 resimden 3.
    • Locate a small black cable that runs along a crevice in the underside of the battery that connects the bottom of the battery to the device. Carefully unplug the side that connects into the battery and remove the cable from its crevice. Then the battery can be removed.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Abby Lunday
231 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 34
Her zaman: 63
