Ana içeriğe geç
Dell Precision 5510 RAM Replacement
Neye ihtiyacın var
  1. Dell Precision 5510 RAM Replacement, Base Cover: adım 1, 1 resimden 1.
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
    According to the owner’s manual at https://www.dell.com/support/manuals/en-..., most of the screws for the base cover are Torx #5 with a couple of Phillips #0 under the badge flap.
    KCMax - Yanıt
  2. Dell Precision 5510 RAM Replacement: adım 2, 1 resimden 1.
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 RAM Replacement, RAM: adım 3, 2 resimden 1. Dell Precision 5510 RAM Replacement, RAM: adım 3, 2 resimden 2.
    • Chose which RAM board you will be replacing on the motherboard.
    • There are two next to each other. One is outlined here.
  4. Dell Precision 5510 RAM Replacement: adım 4, 1 resimden 1.
    • Place fingers on black plastic tabs.
    • Bend the tabs slightly away from the RAM board until the RAM board springs upward.
  5. Dell Precision 5510 RAM Replacement: adım 5, 1 resimden 1.
    • Once the RAM board springs up to an elevated angle as pictured here, gently grab the board.
    • Pull the board (in the direction shown) out of its slot where it is still inserted .
  6. Dell Precision 5510 RAM Replacement: adım 6, 1 resimden 1.
    • If replacing both RAM boards, follow the same process for removal of the other RAM board.
    • The other board is directly to the right of the prior pictured one, and identical. Both are outlined in this picture.
Sonuç
Cooper Zuranski
109 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Harley Spring 2022 IUPUI, Team 2-1, Harley Spring 2022 üyesi
IUPUI-HARLEY-S22S2G1
4 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
T4 Torx is listed under required tools, but T5 is the correct size for my 5510.
Chris - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 31
Her zaman: 537
