Ana içeriğe geç
Dell Precision M3800 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Precision M3800 Keyboard Replacement, Back Cover: adım 1, 2 resimden 1. Dell Precision M3800 Keyboard Replacement, Back Cover: adım 1, 2 resimden 2.
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
  2. Dell Precision M3800 Keyboard Replacement: adım 2, 1 resimden 1.
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
  3. Dell Precision M3800 Keyboard Replacement, Battery: adım 3, 1 resimden 1.
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
  4. Dell Precision M3800 Keyboard Replacement, RAM (Memory): adım 4, 3 resimden 1. Dell Precision M3800 Keyboard Replacement, RAM (Memory): adım 4, 3 resimden 2. Dell Precision M3800 Keyboard Replacement, RAM (Memory): adım 4, 3 resimden 3.
    • Pull the small silver RAM tabs outwards to pop it out of its place in the laptop body.
    • Remove the RAM from the laptop body (it should easily come out after pulling the silver tabs).
  5. Dell Precision M3800 Keyboard Replacement, USB Port: adım 5, 3 resimden 1. Dell Precision M3800 Keyboard Replacement, USB Port: adım 5, 3 resimden 2. Dell Precision M3800 Keyboard Replacement, USB Port: adım 5, 3 resimden 3.
    • Disconnect the orange wire with the two pull tabs by pulling upwards on the pull tabs.
  6. Dell Precision M3800 Keyboard Replacement: adım 6, 3 resimden 1. Dell Precision M3800 Keyboard Replacement: adım 6, 3 resimden 2. Dell Precision M3800 Keyboard Replacement: adım 6, 3 resimden 3.
    • Remove the single 3.5 mm screw at the top of the left side holding the silver bracket using a Phillips #00 screwdriver.
    • Remove the LAN chip by pulling from the top away from the connector.
  7. Dell Precision M3800 Keyboard Replacement: adım 7, 3 resimden 1. Dell Precision M3800 Keyboard Replacement: adım 7, 3 resimden 2. Dell Precision M3800 Keyboard Replacement: adım 7, 3 resimden 3.
    • Disconnect the wires that are connected to left side of the motherboard with a hooked prying tool.
  8. Dell Precision M3800 Keyboard Replacement: adım 8, 2 resimden 1. Dell Precision M3800 Keyboard Replacement: adım 8, 2 resimden 2.
    • Disconnect the black wire that is connected to left side of the motherboard.
  9. Dell Precision M3800 Keyboard Replacement: adım 9, 3 resimden 1. Dell Precision M3800 Keyboard Replacement: adım 9, 3 resimden 2. Dell Precision M3800 Keyboard Replacement: adım 9, 3 resimden 3.
    • Unscrew the three 3.5 mm screws that secure the circuit board using a Phillips #00 screwdriver.
    • Remove the circuit board by lifting upward.
    • To fully remove the USB ports from the circuit board, you'll need to desolder the points. Use the How to Solder and Desolder Connections guide for more information on soldering and desoldering connections.
  10. Dell Precision M3800 Keyboard Replacement, Fan: adım 10, 2 resimden 1. Dell Precision M3800 Keyboard Replacement, Fan: adım 10, 2 resimden 2.
    • Use a Phillips #00 screwdriver to unscrew the two 3.5mm screws that are holding the fans in place.
  11. Dell Precision M3800 Keyboard Replacement: adım 11, 3 resimden 1. Dell Precision M3800 Keyboard Replacement: adım 11, 3 resimden 2. Dell Precision M3800 Keyboard Replacement: adım 11, 3 resimden 3.
    • Using a nonmetal prying tool, unplug the cord connecting the fan to the motherboard.
    • If replacing the right fan, this cord is located underneath the fan.
    • If replacing the left fan, this cord is located on the left of the fan.
  12. Dell Precision M3800 Keyboard Replacement: adım 12, 2 resimden 1. Dell Precision M3800 Keyboard Replacement: adım 12, 2 resimden 2.
    • Use nonmetal prying tool to lift the bottom of the fan from the laptop body (this will require some force and you will hear an adhesive pulling sound).
    • Repeat the steps for the second fan if needed .
  13. Dell Precision M3800 Keyboard Replacement, Keyboard: adım 13, 3 resimden 1. Dell Precision M3800 Keyboard Replacement, Keyboard: adım 13, 3 resimden 2. Dell Precision M3800 Keyboard Replacement, Keyboard: adım 13, 3 resimden 3.
    • Disconnect the 6 wires that are attached to the motherboard.
    • Three of the six wires have a clasp holding the wire. Pull up on the tab and remove the wire.
    • The other three wires have pull tabs and can be removed by pulling from the connector of the wire.
  14. Dell Precision M3800 Keyboard Replacement: adım 14, 3 resimden 1. Dell Precision M3800 Keyboard Replacement: adım 14, 3 resimden 2. Dell Precision M3800 Keyboard Replacement: adım 14, 3 resimden 3.
    • Unscrew the six 3.5mm screws using the Phillips #00 screwdriver.
    • Lift the motherboard out of the laptop body to expose the backing of the keyboard.
  15. Dell Precision M3800 Keyboard Replacement: adım 15, 3 resimden 1. Dell Precision M3800 Keyboard Replacement: adım 15, 3 resimden 2. Dell Precision M3800 Keyboard Replacement: adım 15, 3 resimden 3.
    • Remove the black piece of tape at the top of the keyboard.
    • Unscrew the fifteen screws with a 2 millimeter 000 Philips Head.
  16. Dell Precision M3800 Keyboard Replacement: adım 16, 3 resimden 1. Dell Precision M3800 Keyboard Replacement: adım 16, 3 resimden 2. Dell Precision M3800 Keyboard Replacement: adım 16, 3 resimden 3.
    • Using a prying tool, place wedges underneath the keyboard until the entire keyboard is removed.
Sonuç
1Rehber Yorum
Reminder: There are more than 15 screws to unscrew on the keyboard (Step 14). They’re hidden under the “K”s.
You shouldn’t apply force to remove the keyboard.
Felipe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 56
Her zaman: 2,764
