Ana içeriğe geç
Dell Vostro 1710 RAM Replacement
Sarah Dulac
Sarah Dulac ve 4 diğer katkıda bulunanlar
En son October 1, 2019 tarihinde güncellendi
10 - 15 dakika
Orta
Öne Çıkan Öğrenci Kılavuzu
RAM is needed for a computer to function. If your computer is crashing you may have old or damaged RAM. It can be damaged by static electricity and if it is not removed or inserted correctly. Adding more RAM to your computer can improve its performance drastically.
Neye ihtiyacın var
Aletler
  1. Dell Vostro 1710 RAM Replacement, Battery: adım 1, 2 resimden 1. Dell Vostro 1710 RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 RAM Replacement: adım 2, 1 resimden 1.
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 RAM Replacement: adım 3, 1 resimden 1.
    • Remove the battery from the slot.
  4. Dell Vostro 1710 RAM Replacement, Back Panel: adım 4, 2 resimden 1. Dell Vostro 1710 RAM Replacement, Back Panel: adım 4, 2 resimden 2.
    • Unscrew the eight 6mm screws with a Philips #1 screw driver.
  5. Dell Vostro 1710 RAM Replacement: adım 5, 1 resimden 1.
    • Lift back cover from the groove on the left side of the cover next to the symbol.
  6. Dell Vostro 1710 RAM Replacement, RAM: adım 6, 2 resimden 1. Dell Vostro 1710 RAM Replacement, RAM: adım 6, 2 resimden 2.
    • Push the metal tabs outward and away from the RAM.
  7. Dell Vostro 1710 RAM Replacement: adım 7, 2 resimden 1. Dell Vostro 1710 RAM Replacement: adım 7, 2 resimden 2.
    • Pull the top piece straight out of the socket.
  8. Dell Vostro 1710 RAM Replacement: adım 8, 2 resimden 1. Dell Vostro 1710 RAM Replacement: adım 8, 2 resimden 2.
    • Repeat the same process by pushing the bottom metal tabs outward and away from the RAM.
  9. Dell Vostro 1710 RAM Replacement: adım 9, 2 resimden 1. Dell Vostro 1710 RAM Replacement: adım 9, 2 resimden 2.
    • Pull the bottom piece straight out of the socket.
Sonuç
Sarah Dulac
270 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G7, Peak Spring 2018 UMass Dartmouth, Team S3-G7, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G7
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 547
