Ana içeriğe geç
Dell XPS 12 9Q33 Battery Replacement
Neye ihtiyacın var
  1. Dikkatli ol: adımlar 1-3 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
    Dell XPS 12 9Q33 Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Be sure to power off and unplug your device before you begin your repair.
    • Use your fingers or a spudger to pry up the system badge from the bottom of the laptop.
  2. Dell XPS 12 9Q33 Battery Replacement: adım 2, 1 resimden 1.
    • Use a Phillips screwdriver to remove the eleven screws securing the base cover.
  3. Dell XPS 12 9Q33 Battery Replacement: adım 3, 1 resimden 1.
    • Beginning with the side opposite the power switch, use your fingers to pry up the base cover from the laptop.
    • Carefully lift the base cover around the power switch and remove the cover.
  4. Dell XPS 12 9Q33 Battery Replacement, Removing the Battery: adım 4, 1 resimden 1.
    • Slide the battery cable connector out of its system board socket.
    • Pull parallel to the motherboard, not straight up, or you will damage the socket.
    • Remove the screws that secure the battery to the palm-rest assembly.
    • Lift and remove the battery along with its cable.
    • Slide and hold the power switch for about five seconds to ground the system board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Johnathan Hammond
44.980 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.989 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 1,099
