Ana içeriğe geç
Dell XPS 13 9310 Lower Case Replacement
Neye ihtiyacın var
  1. Dell XPS 13 9310 Lower Case Replacement, Unfasten the lower case: adım 1, 2 resimden 1. Dell XPS 13 9310 Lower Case Replacement, Unfasten the lower case: adım 1, 2 resimden 2.
    • Use a T5 Torx screwdriver to remove the eight 3.3 mm screws securing the case.
    FixBot'a Sor
    Yorum Ekle
  2. Dell XPS 13 9310 Lower Case Replacement, Insert an opening pick: adım 2, 2 resimden 1. Dell XPS 13 9310 Lower Case Replacement, Insert an opening pick: adım 2, 2 resimden 2.
    • Insert an opening pick between the lower case and the chassis on the front right edge.
    FixBot'a Sor
    Yorum Ekle
  3. Dell XPS 13 9310 Lower Case Replacement, Release the case's front clips: adım 3, 2 resimden 1. Dell XPS 13 9310 Lower Case Replacement, Release the case's front clips: adım 3, 2 resimden 2.
    • Slide the pick along the front edge to release the clips securing the lower case.
    FixBot'a Sor
    Yorum Ekle
  4. Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: adım 4, 3 resimden 1. Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: adım 4, 3 resimden 2. Dell XPS 13 9310 Lower Case Replacement, Release the remaining clips: adım 4, 3 resimden 3.
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
    FixBot'a Sor
    Yorum Ekle
  5. Dell XPS 13 9310 Lower Case Replacement: adım 5, 3 resimden 1. Dell XPS 13 9310 Lower Case Replacement: adım 5, 3 resimden 2. Dell XPS 13 9310 Lower Case Replacement: adım 5, 3 resimden 3.
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Dell XPS answers community for help.
14 farklı kişi bu kılavuzu tamamladı.
Spencer Day
190.602 İtibar
1.204 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
25.930 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 60
Son 30 gün: 253
Her zaman: 5,940
