Ana içeriğe geç
Dell XPS 14 RAM Replacement
Neye ihtiyacın var
  1. Dell XPS 14 RAM Replacement, Back Panel: adım 1, 1 resimden 1.
    • Position the computer back side up so that the “XPS” logo is facing you.
    • Remove six 3 mm screws along the perimeter of the back panel using a T5 Torx screwdriver.
  2. Dell XPS 14 RAM Replacement: adım 2, 3 resimden 1. Dell XPS 14 RAM Replacement: adım 2, 3 resimden 2. Dell XPS 14 RAM Replacement: adım 2, 3 resimden 3.
    • Use an opening tool to pry up the metal plate.
    • Remove the two 6 mm screws under the silver flap using a Phillips #0 screwdriver.
  3. Dell XPS 14 RAM Replacement: adım 3, 2 resimden 1. Dell XPS 14 RAM Replacement: adım 3, 2 resimden 2.
    • Use an opening tool to pop out the back panel.
    • Once unhinged, the panel will open away from you.
    • The back panel will still be attached by a ribbon cable. Be cautious when opening the panel to ensure the ribbon stays intact.
  4. Dell XPS 14 RAM Replacement: adım 4, 3 resimden 1. Dell XPS 14 RAM Replacement: adım 4, 3 resimden 2. Dell XPS 14 RAM Replacement: adım 4, 3 resimden 3.
    • Flip over the back panel so that the interior of the panel is facing up.
    • Remove three 2 mm screws that are connected to the vendor GCE disk on the bottom left corner of the back panel using a Phillips #0 screwdriver.
    • Remove the black plastic cover that holds the disk in place.
    • Remove the back panel.
    • The GCE disk should still be connected to the computer via a purple ribbon cable.
  5. Dell XPS 14 RAM Replacement, Speaker: adım 5, 2 resimden 1. Dell XPS 14 RAM Replacement, Speaker: adım 5, 2 resimden 2.
    • Remove four 2 mm screws that are connected to the speaker using a Phillips #0 screwdriver.
  6. Dell XPS 14 RAM Replacement: adım 6, 2 resimden 1. Dell XPS 14 RAM Replacement: adım 6, 2 resimden 2.
    • Remove the speaker from its original location so the wire connector is visible.
    • Unplug the red and white cable plug by pulling out the white end tag.
    • The speaker is now fully removed.
  7. Dell XPS 14 RAM Replacement, Battery: adım 7, 1 resimden 1.
    • Make sure to ground yourself before removing the battery.
    • Remove the four 6 mm screws from the sides of the battery using a T5 Torx screwdriver.
    • Remove the two 3 mm screws from the top of the battery using a Phillips #0 screwdriver.
  8. Dell XPS 14 RAM Replacement: adım 8, 3 resimden 1. Dell XPS 14 RAM Replacement: adım 8, 3 resimden 2. Dell XPS 14 RAM Replacement: adım 8, 3 resimden 3.
    • Detach the battery connector from the motherboard using two thumbs to pop it out.
    • Remove the battery from the laptop.
  9. Dell XPS 14 RAM Replacement, RAM: adım 9, 3 resimden 1. Dell XPS 14 RAM Replacement, RAM: adım 9, 3 resimden 2. Dell XPS 14 RAM Replacement, RAM: adım 9, 3 resimden 3.
    • Remove any electrical tape that may be covering or overlapping the RAM cartridge.
    • Push the two metal latches on either side of the RAM outward.
    • The cartridge will pop out of the laptop.
  10. Dell XPS 14 RAM Replacement: adım 10, 2 resimden 1. Dell XPS 14 RAM Replacement: adım 10, 2 resimden 2.
    • Slide the RAM cartridge out of its slot.
Sonuç
Gabriella Monico
457 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Botvin Spring 2022 UMass Dartmouth, Team 1-3, Botvin Spring 2022 üyesi
UMASSD-BOTVIN-S22S1G3
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 385
