Ana içeriğe geç
Dell XPS 15 9510 Battery Replacement
Neye ihtiyacın var
  1. Dell XPS 15 9510 Battery Replacement, Lower Case: adım 1, 1 resimden 1.
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Battery Replacement: adım 2, 1 resimden 1.
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Battery Replacement: adım 3, 1 resimden 1.
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Battery Replacement, Battery: adım 4, 2 resimden 1. Dell XPS 15 9510 Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Using the small battery pull tab, disconnect the battery connector from the motherboard.
  5. Dell XPS 15 9510 Battery Replacement: adım 5, 1 resimden 1.
    • Remove eight 2.5 mm from around the perimeter of the battery using a Phillips #0 screwdriver.
  6. Dell XPS 15 9510 Battery Replacement: adım 6, 2 resimden 1. Dell XPS 15 9510 Battery Replacement: adım 6, 2 resimden 2.
    • There are many delicate components in the vicinity of the battery, so be extremely careful removing it
    • Remove the old battery from the laptop.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Joseph Remondi
290 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Mellen Spring 2022 UMass Dartmouth, Team 1-3, Mellen Spring 2022 üyesi
UMASSD-MELLEN-S22S1G3
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
XPS 15 9510 states the battery (purchased from ifixit) is FAKE and the battery will not charge.
Jacques Aucamp - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 76
Son 30 gün: 363
Her zaman: 6,787
