Ana içeriğe geç
Dell XPS 15 9510 Fan Replacement
Neye ihtiyacın var
  1. Dell XPS 15 9510 Fan Replacement, Lower Case: adım 1, 1 resimden 1.
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Fan Replacement: adım 2, 1 resimden 1.
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Fan Replacement: adım 3, 1 resimden 1.
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Fan Replacement, Fan: adım 4, 2 resimden 1. Dell XPS 15 9510 Fan Replacement, Fan: adım 4, 2 resimden 2.
    • Remove two 4.3 mm screws from the left fan and one 4.3 mm screw from the right fan using a JIS #000 screwdriver.
  5. Dell XPS 15 9510 Fan Replacement: adım 5, 2 resimden 1. Dell XPS 15 9510 Fan Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Gently unplug the motherboard fan connector using a pair of tweezers.
  6. Dell XPS 15 9510 Fan Replacement: adım 6, 1 resimden 1.
    • Unplug the motherboard connector on the other fan using a pair of tweezers.
  7. Dell XPS 15 9510 Fan Replacement: adım 7, 2 resimden 1. Dell XPS 15 9510 Fan Replacement: adım 7, 2 resimden 2.
    • Gently slide and then lift the fans out of their positions.
  8. Dell XPS 15 9510 Fan Replacement: adım 8, 3 resimden 1. Dell XPS 15 9510 Fan Replacement: adım 8, 3 resimden 2. Dell XPS 15 9510 Fan Replacement: adım 8, 3 resimden 3.
    • Repeat the previous step and remove the other fan.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bethany Wright
439 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Harley Summer 2023 IUPUI, Team 2-1, Harley Summer 2023 üyesi
IUPUI-HARLEY-SU23S2G1
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 23
Son 30 gün: 83
Her zaman: 1,279
