Giriş
Use this guide to remove and replace the back cover on your Dell XPS 9520.
The cover on this XPS is very sharp and is secured tightly to the laptop body. Work slowly to prevent cutting your hands.
Neye ihtiyacın var
Use a Torx T5 screwdriver to remove the eight 3.3 mm-long screws securing the back cover.
Insert an opening pick between the bottom-left corner of the aluminum back cover and the chassis.
Leave the pick inserted before continuing to the next step.
Insert the flat end of the spudger into the gap you just created.
Pry up to release the corner clips.
Repeat this process for the opposite corner of the back cover.
Reinsert your opening pick under the aluminum cover at the front edge of the laptop.
Pry to loosen the cover.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell XPS answers community for help.
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
While we can't say for sure without having the device in our hands, the back cover comes off relatively the same between newer XPS models. A Torx driver and unclipping the front half of the cover will more than likely get you into the laptop.
