Ana içeriğe geç
Dell XPS 15 9570 Battery Replacement
Neye ihtiyacın var
  1. Dell XPS 15 9570 Battery Replacement, Base Cover: adım 1, 1 resimden 1.
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Battery Replacement: adım 2, 3 resimden 1. Dell XPS 15 9570 Battery Replacement: adım 2, 3 resimden 2. Dell XPS 15 9570 Battery Replacement: adım 2, 3 resimden 3.
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Battery Replacement: adım 3, 2 resimden 1. Dell XPS 15 9570 Battery Replacement: adım 3, 2 resimden 2.
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Battery Replacement: adım 4, 1 resimden 1.
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Battery Replacement, Battery: adım 5, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Battery Replacement: adım 6, 1 resimden 1.
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Battery Replacement: adım 7, 1 resimden 1.
    • With your hands, pick up and remove the battery from the system.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Clay Caldwell
369 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 78
Son 30 gün: 376
Her zaman: 22,066
