Giriş
Follow this guide if you need to replace the heat sink of your Dell XPS 15 9570. You may need to complete this replacement if your computer is overheating or if you wish to apply more thermal paste.
Before starting this guide, power the laptop off and disconnect from the charger.
Neye ihtiyacın var
Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
