Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Dell XPS 17 L702X Palm Rest Replacement
Neye ihtiyacın var
  1. Dell XPS 17 L702X Palm Rest Replacement, Battery: adım 1, 1 resimden 1.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip over the laptop so that the bottom battery compartment faces upwards.
  2. Dell XPS 17 L702X Palm Rest Replacement: adım 2, 2 resimden 1. Dell XPS 17 L702X Palm Rest Replacement: adım 2, 2 resimden 2.
    • Slide the tab below the battery to the left and hold the tab in place.
  3. Dell XPS 17 L702X Palm Rest Replacement: adım 3, 2 resimden 1. Dell XPS 17 L702X Palm Rest Replacement: adım 3, 2 resimden 2.
    • While holding the tab, lift the battery out of its compartment.
    • Release the tab after removing the battery.
  4. Dell XPS 17 L702X Palm Rest Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Loosen the module cover screw with a Phillips screwdriver.
    • The screw is attached to the cover; do not force it out.
  5. Dell XPS 17 L702X Palm Rest Replacement: adım 5, 3 resimden 1. Dell XPS 17 L702X Palm Rest Replacement: adım 5, 3 resimden 2. Dell XPS 17 L702X Palm Rest Replacement: adım 5, 3 resimden 3.
    • Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
  6. Dell XPS 17 L702X Palm Rest Replacement: adım 6, 2 resimden 1. Dell XPS 17 L702X Palm Rest Replacement: adım 6, 2 resimden 2.
    • Remove the four 4mm Phillips screws fastening the first hard drive.
  7. Dell XPS 17 L702X Palm Rest Replacement: adım 7, 3 resimden 1. Dell XPS 17 L702X Palm Rest Replacement: adım 7, 3 resimden 2. Dell XPS 17 L702X Palm Rest Replacement: adım 7, 3 resimden 3.
    • Slide the hard drive with your hand towards the hole where the back panel assembly screw was located (in step 5) to disconnect it.
    • Lift the hard drive up to remove it from the case.
  8. Dell XPS 17 L702X Palm Rest Replacement: adım 8, 1 resimden 1.
    • Remove the four 4mm Phillips screws on the second hard drive.
  9. Dell XPS 17 L702X Palm Rest Replacement: adım 9, 2 resimden 1. Dell XPS 17 L702X Palm Rest Replacement: adım 9, 2 resimden 2.
    • Slide the hard drive towards the edge nearest you to disconnect it.
  10. Dell XPS 17 L702X Palm Rest Replacement: adım 10, 3 resimden 1. Dell XPS 17 L702X Palm Rest Replacement: adım 10, 3 resimden 2. Dell XPS 17 L702X Palm Rest Replacement: adım 10, 3 resimden 3.
    • Using the tab that says "THIS SIDE UP," pull away from the laptop to remove the hard drive.
  11. Dell XPS 17 L702X Palm Rest Replacement: adım 11, 2 resimden 1. Dell XPS 17 L702X Palm Rest Replacement: adım 11, 2 resimden 2.
    • Repeat this step for each hard drive.
    • Unscrew the two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
  12. Dell XPS 17 L702X Palm Rest Replacement: adım 12, 1 resimden 1.
    • Remove the hard drive casing.
  13. Dell XPS 17 L702X Palm Rest Replacement, Palm Rest: adım 13, 1 resimden 1.
    • Unscrew the screw holding the optical drive with a Phillips screwdriver.
  14. Dell XPS 17 L702X Palm Rest Replacement: adım 14, 3 resimden 1. Dell XPS 17 L702X Palm Rest Replacement: adım 14, 3 resimden 2. Dell XPS 17 L702X Palm Rest Replacement: adım 14, 3 resimden 3.
    • Using a plastic opening tool, pull out the optical drive.
  15. Dell XPS 17 L702X Palm Rest Replacement: adım 15, 1 resimden 1.
    • Unscrew three 4mm screws near the edge of the optical drive compartment with a Phillips screwdriver.
  16. Dell XPS 17 L702X Palm Rest Replacement: adım 16, 1 resimden 1.
    • Open the laptop to about a 90 degree angle and place it on its side with the empty optical drive slot pointing upwards.
  17. Dell XPS 17 L702X Palm Rest Replacement: adım 17, 3 resimden 1. Dell XPS 17 L702X Palm Rest Replacement: adım 17, 3 resimden 2. Dell XPS 17 L702X Palm Rest Replacement: adım 17, 3 resimden 3.
    • Push and hold the tab inside the optical drive's opening with your index finger.
    • Insert a spudger between the black and silver plastic pieces that are above the tab and pry apart the two pieces.
  18. Dell XPS 17 L702X Palm Rest Replacement: adım 18, 2 resimden 1. Dell XPS 17 L702X Palm Rest Replacement: adım 18, 2 resimden 2.
    • Slide the spudger around the palm rest to release the clips.
    • You may hear a crackling noise; this is normal.
    • Use caution when sliding below the mouse pad, as there are wires we must detach in the next steps.
  19. Dell XPS 17 L702X Palm Rest Replacement: adım 19, 2 resimden 1. Dell XPS 17 L702X Palm Rest Replacement: adım 19, 2 resimden 2.
    • Gently lift and rotate the palm rest panel until it's upside down as it is still connected by the mouse pad wires.
    • The mouse pad wires are still connected to the palm rest panel.
  20. Dell XPS 17 L702X Palm Rest Replacement: adım 20, 3 resimden 1. Dell XPS 17 L702X Palm Rest Replacement: adım 20, 3 resimden 2. Dell XPS 17 L702X Palm Rest Replacement: adım 20, 3 resimden 3.
    • Put the spudger below the black tab of the wider cable and push up to release.
    • Gently pull out the cable.
  21. Dell XPS 17 L702X Palm Rest Replacement: adım 21, 3 resimden 1. Dell XPS 17 L702X Palm Rest Replacement: adım 21, 3 resimden 2. Dell XPS 17 L702X Palm Rest Replacement: adım 21, 3 resimden 3.
    • Insert the spudger below the black tab of the remaining cable and push up to release.
  22. Dell XPS 17 L702X Palm Rest Replacement: adım 22, 1 resimden 1.
    • Remove the palm rest from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Shin Sul
544 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-6, Bruce Fall 2015 CSU Fullerton, Team 2-6, Bruce Fall 2015 üyesi
CSUF-BRUCE-F15S2G6
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 1,159
