Ana içeriğe geç
Dell XPS M1530 Thermal Compound Replacement
Neye ihtiyacın var
    1. Dell XPS M1530 Thermal Compound Replacement, Battery: adım 1, 1 resimden 1.
      • Turn the computer upside down with the battery facing you.
      • Turn the computer off and disconnect the charging cable from the computer.
      • Failure to unplug the charging cable may result in electric shock.
      FixBot'a Sor
      Yorum Ekle
    2. Dell XPS M1530 Thermal Compound Replacement: adım 2, 1 resimden 1.
      • Push the switch as far to the right as possible to unlock the battery.
      FixBot'a Sor
      Yorum Ekle
    3. Dell XPS M1530 Thermal Compound Replacement: adım 3, 2 resimden 1. Dell XPS M1530 Thermal Compound Replacement: adım 3, 2 resimden 2.
      • Remove the battery using two hands and pull it away from the computer.
      FixBot'a Sor
      Yorum Ekle
    1. Dell XPS M1530 Thermal Compound Replacement, Heat Sink: adım 4, 1 resimden 1.
      • Unscrew the four Phillips #1 screws holding down the back panel. Then remove one 5.8mm Phillips #1 screw labeled "M" in the middle of the back panel.
      • Four 3.9mm Phillips #1 screws
      • One 5.8mm Phillips #1 screw
      FixBot'a Sor
      Yorum Ekle
    2. Dell XPS M1530 Thermal Compound Replacement: adım 5, 2 resimden 1. Dell XPS M1530 Thermal Compound Replacement: adım 5, 2 resimden 2.
      • Using the highlighted indent, pull up and out to remove the back panel.
      • The indent should provide enough grip to remove the panel with ease.
      FixBot'a Sor
      Yorum Ekle
    3. Dell XPS M1530 Thermal Compound Replacement: adım 6, 2 resimden 1. Dell XPS M1530 Thermal Compound Replacement: adım 6, 2 resimden 2.
      • First, unscrew the six screws that are holding down the fan and heat sink with a Philips #1 screwdriver. Then use a Phillips #1 to remove the single screw near the bottom of the heat sink.
      • Six Silver Chrome 5.8mm Phillips #1 screws
      • Remove the four screws that are holding down the CPU (the four to the top left that form a rectangle in this image) first. Unscrew them in an X pattern (eg. top left screw, bottom right screw, top right screw, bottom left screw) to minimize risk of harming CPU.
      FixBot'a Sor
      Yorum Ekle
    4. Dell XPS M1530 Thermal Compound Replacement: adım 7, 2 resimden 1. Dell XPS M1530 Thermal Compound Replacement: adım 7, 2 resimden 2.
      • Carefully lift the fan and heat sink from the laptop.
      • Be careful not to pull up too hard, because the power pin is still connecting the fan to the laptop.
      FixBot'a Sor
      Yorum Ekle
    5. Dell XPS M1530 Thermal Compound Replacement: adım 8, 1 resimden 1.
      • Use your fingers or a spudger to remove the power pin connecting the fan to the laptop by pulling it straight up off the motherboard.
      FixBot'a Sor
      Yorum Ekle
    6. Dell XPS M1530 Thermal Compound Replacement: adım 9, 1 resimden 1.
      • Remove the fan and heat sink from the laptop.
      • When installing the new heat sink, do not forget to replace the thermal paste underneath the heat sink. See iFixit's Applying Thermal Paste guide for further instructions.
      FixBot'a Sor
      Yorum Ekle
    1. Dell XPS M1530 Thermal Compound Replacement, Thermal Compound: adım 10, 2 resimden 1. Dell XPS M1530 Thermal Compound Replacement, Thermal Compound: adım 10, 2 resimden 2.
      • Clean the CPU, GPU and heat sink with 90% isopropyl alcohol dabbed onto a paper towel.
      • CPU Compound
      • GPU Compound
      • Thermal Pad
      • Heat sink compound
      • It is not necessary to replace the thermal pad, it is the soft square material.
      • 70% isopropyl alcohol can also work if 90% is not available.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tyler Scholz
479 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-4, Maness Winter 2015 Cal Poly, Team 18-4, Maness Winter 2015 üyesi
CPSU-MANESS-W15S18G4
4 Üyeler
80 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 2,747
