Ana içeriğe geç
Dewalt Air Compressor DWFP55126 2016 Pump Replacement
Neye ihtiyacın var
  1. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove manifold cover: adım 1, 3 resimden 1. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove manifold cover: adım 1, 3 resimden 2. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove manifold cover: adım 1, 3 resimden 3.
    • Disconnect the power cord, depressurize the compressor tank, and remove any hoses before starting this repair.
    • Use a long-shank T10 driver to remove the manifold cover screw.
    • Lift the cover directly up off of the gauges to remove.
  2. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove handle: adım 2, 2 resimden 1. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove handle: adım 2, 2 resimden 2.
    • Use a T20 driver to remove the two handle screws, one on each side.
  3. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: adım 3, 3 resimden 1. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: adım 3, 3 resimden 2. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: adım 3, 3 resimden 3.
    • Grab the handle like you would if you were to pick the compressor up. Pull up and push forward away from the gauges at the same time to rotate the handle up off the case.
    • Lift the handle off to remove.
  4. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove top case: adım 4, 3 resimden 1. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove top case: adım 4, 3 resimden 2. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove top case: adım 4, 3 resimden 3.
    • Remove the following four screws:
    • Three 20 mm-long T20 screws.
    • One 20 mm-long Phillips #1 screw.
  5. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: adım 5, 2 resimden 1. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: adım 5, 2 resimden 2.
    • Four metal tabs on the tank sit in four slots on the top plastic case to secure the case to the tank.
    • Firmly push the top case off of the four tabs to detach.
  6. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: adım 6, 3 resimden 1. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: adım 6, 3 resimden 2. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: adım 6, 3 resimden 3.
    • Carefully pull the half of the case that is opposite the manifold away from the tank.
    • The motor may shift once the case is removed, but it won't fall out.
    • Reassembly tip: align the power cord in the cord cutout so it doesn't get pinched.
  7. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove power switch: adım 7, 3 resimden 1. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove power switch: adım 7, 3 resimden 2. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove power switch: adım 7, 3 resimden 3.
    • Use a large flathead screwdriver to depress the plastic tab on the red power switch closest to the open side of the case.
    • While keeping the tab depressed, grab the top side of the switch and pull directly up off the case.
    • Pull the switch farther out of the case.
    • Don't try to completely remove the switch; there are still wires attached below.
  8. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: adım 8, 2 resimden 1. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: adım 8, 2 resimden 2.
    • Use a flathead screwdriver to pry both wire connectors slightly off the plugs on the bottom of the switch.
  9. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: adım 9, 2 resimden 1. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: adım 9, 2 resimden 2.
    • Once the wires are loosened from the plugs on the switch, completely remove both wires.
    • Remove the power switch.
  10. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove ground wire: adım 10, 2 resimden 1. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove ground wire: adım 10, 2 resimden 2.
    • Carefully pull to remove the connector on the ground wire located inside the case.
  11. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove check valve hose: adım 11, 3 resimden 1. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove check valve hose: adım 11, 3 resimden 2. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove check valve hose: adım 11, 3 resimden 3.
    • Use needle nose pliers to bend the check valve hose clamp up away from the hose.
    • Once the hose clamp is bent enough to clear the hose, lift it up and off to remove.
    • We strongly suggest you replace this hose clamp during reassembly to prevent leaks during operation.
  12. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: adım 12, 2 resimden 1. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: adım 12, 2 resimden 2.
    • Pull the hose off the fitting to remove.
  13. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove pump assembly: adım 13, 2 resimden 1. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove pump assembly: adım 13, 2 resimden 2.
    • While holding the plastic housing, pull the pump assembly out, careful to not snag hoses or wires.
Sonuç
Carsten Frauenheim
113.865 İtibar
338 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
17.125 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 84
Her zaman: 2,512
