Ana içeriğe geç
Dewalt DCD778 Motor Replacement
Neye ihtiyacın var
    1. Dewalt DCD778 Motor Replacement, Battery: adım 1, 1 resimden 1.
      • Grab the drill in one hand and cup the battery (located at the bottom of the drill) with the other hand.
      FixBot'a Sor
      Yorum Ekle
    2. Dewalt DCD778 Motor Replacement: adım 2, 1 resimden 1.
      • Use your other hand to push down on the yellow button on the battery.
      FixBot'a Sor
      Yorum Ekle
    3. Dewalt DCD778 Motor Replacement: adım 3, 1 resimden 1.
      • Pull the battery in a horizontal direction away from the drill.
      FixBot'a Sor
      Yorum Ekle
    1. Dewalt DCD778 Motor Replacement, Motor: adım 4, 2 resimden 1. Dewalt DCD778 Motor Replacement, Motor: adım 4, 2 resimden 2.
      • Remove the eight 16 mm, Torx Security #15 screws.
      FixBot'a Sor
      Yorum Ekle
    2. Dewalt DCD778 Motor Replacement: adım 5, 1 resimden 1.
      • Lay the drill on its side and gently lift the top half off it.
      FixBot'a Sor
      Yorum Ekle
    3. Dewalt DCD778 Motor Replacement: adım 6, 1 resimden 1.
      • Lift the drill mechanism out of the shell.
      • Desolder the red and black wires from the motor.
      FixBot'a Sor
      Yorum Ekle
    4. Dewalt DCD778 Motor Replacement: adım 7, 2 resimden 1. Dewalt DCD778 Motor Replacement: adım 7, 2 resimden 2.
      • Slightly twist and pull motor away from the clutch.
      FixBot'a Sor
      Yorum Ekle
    5. Dewalt DCD778 Motor Replacement: adım 8, 1 resimden 1.
      • When installing the replacement motor into the clutch make sure you correctly align the gears in order to assure that the motor is properly fitted to the clutch.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brittany
705 İtibar
5 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 14
Son 30 gün: 53
Her zaman: 2,537
