Ana içeriğe geç
Dewalt DCD778 Motor Replacement
Neye ihtiyacın var
  1. Dewalt DCD778 Motor Replacement, Battery: adım 1, 1 resimden 1.
    • Grab the drill in one hand and cup the battery (located at the bottom of the drill) with the other hand.
  2. Dewalt DCD778 Motor Replacement: adım 2, 1 resimden 1.
    • Use your other hand to push down on the yellow button on the battery.
  3. Dewalt DCD778 Motor Replacement: adım 3, 1 resimden 1.
    • Pull the battery in a horizontal direction away from the drill.
  4. Dewalt DCD778 Motor Replacement, Motor: adım 4, 2 resimden 1. Dewalt DCD778 Motor Replacement, Motor: adım 4, 2 resimden 2.
    • Remove the eight 16 mm, Torx Security #15 screws.
  5. Dewalt DCD778 Motor Replacement: adım 5, 1 resimden 1.
    • Lay the drill on its side and gently lift the top half off it.
  6. Dewalt DCD778 Motor Replacement: adım 6, 1 resimden 1.
    • Lift the drill mechanism out of the shell.
    • Desolder the red and black wires from the motor.
  7. Dewalt DCD778 Motor Replacement: adım 7, 2 resimden 1. Dewalt DCD778 Motor Replacement: adım 7, 2 resimden 2.
    • Slightly twist and pull motor away from the clutch.
  8. Dewalt DCD778 Motor Replacement: adım 8, 1 resimden 1.
    • When installing the replacement motor into the clutch make sure you correctly align the gears in order to assure that the motor is properly fitted to the clutch.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brittany
705 İtibar
5 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 72
Her zaman: 1,811
