Ana içeriğe geç
Dexcom G6 Receiver Battery Replacement
Neye ihtiyacın var
  1. Dexcom G6 Receiver Battery Replacement, Display and Front Bezel: adım 1, 1 resimden 1.
    • Unscrew the 6 Torx T5 screws from the back of the device
  2. Dexcom G6 Receiver Battery Replacement: adım 2, 2 resimden 1. Dexcom G6 Receiver Battery Replacement: adım 2, 2 resimden 2.
    • Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
    • Screen Information: Model AM0310R-04 Lot # NHT18080052
  3. Dexcom G6 Receiver Battery Replacement, Charging Port: adım 3, 1 resimden 1.
    • Using a spudger, unplug the Charging Port connector from the motherboard.
  4. Dexcom G6 Receiver Battery Replacement: adım 4, 1 resimden 1.
    • Remove the 2 silver Torx T5 screws holding the charging port down.
  5. Dexcom G6 Receiver Battery Replacement: adım 5, 1 resimden 1.
    • Remove the Charging Port Assembly from the motherboard.
  6. Dexcom G6 Receiver Battery Replacement, Motherboard: adım 6, 1 resimden 1.
    • Remove the silver Torx T5 screw holding the motherboard down.
  7. Dexcom G6 Receiver Battery Replacement: adım 7, 2 resimden 1. Dexcom G6 Receiver Battery Replacement: adım 7, 2 resimden 2.
    • Using a spudger, carefully remove the battery connector on the left side of the motherboard.
  8. Dexcom G6 Receiver Battery Replacement: adım 8, 1 resimden 1.
    • Using a spudger, carefully pry up the motherboard to remove it.
  9. Dexcom G6 Receiver Battery Replacement, Battery: adım 9, 3 resimden 1. Dexcom G6 Receiver Battery Replacement, Battery: adım 9, 3 resimden 2. Dexcom G6 Receiver Battery Replacement, Battery: adım 9, 3 resimden 3.
    • Use heat to soften the adhesive holding the battery down.
    • Carefully use one or more opening picks to remove the adhesive holding the battery down, then remove the battery.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Andrew S
15.525 İtibar
8 adet Kılavuz yazıldı
10Kılavuz Yorumları
Where do you get battery? Dexcom won't sell it.
Richy - Yanıt Paylaş
I'm not sure you can get this same battery somewhere else (I haven't performed a battery change myself, just took it apart for demonstration). I'll get back to you if I can figure out a way to use another battery.
Andrew S - Paylaş
@richy14330 The connector type is JST ACHR-03V.
Andrew S - Yanıt Paylaş
Still looking ... Where to get a battery for this receiver? What type of battery is it ?
Julian Payne (Xfactor) - Yanıt Paylaş
I don't think you can get a replacement battery for this device anywhere. It is a 950 mAh 06220 battery made by Jhih Hong Technology. The model number seems to be BAT000023 and the type is 1ICP4/44/59.
Andrew S - Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 46
Her zaman: 4,968
