Ana içeriğe geç
Dexcom G6 Receiver Motherboard Replacement
Neye ihtiyacın var
  1. Dexcom G6 Receiver Motherboard Replacement, Display and Front Bezel: adım 1, 1 resimden 1.
    • Unscrew the 6 Torx T5 screws from the back of the device
  2. Dexcom G6 Receiver Motherboard Replacement: adım 2, 2 resimden 1. Dexcom G6 Receiver Motherboard Replacement: adım 2, 2 resimden 2.
    • Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
    • Screen Information: Model AM0310R-04 Lot # NHT18080052
  3. Dexcom G6 Receiver Motherboard Replacement, Charging Port: adım 3, 1 resimden 1.
    • Using a spudger, unplug the Charging Port connector from the motherboard.
  4. Dexcom G6 Receiver Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the 2 silver Torx T5 screws holding the charging port down.
  5. Dexcom G6 Receiver Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the Charging Port Assembly from the motherboard.
  6. Dexcom G6 Receiver Motherboard Replacement, Motherboard: adım 6, 1 resimden 1.
    • Remove the silver Torx T5 screw holding the motherboard down.
  7. Dexcom G6 Receiver Motherboard Replacement: adım 7, 2 resimden 1. Dexcom G6 Receiver Motherboard Replacement: adım 7, 2 resimden 2.
    • Using a spudger, carefully remove the battery connector on the left side of the motherboard.
  8. Dexcom G6 Receiver Motherboard Replacement: adım 8, 1 resimden 1.
    • Using a spudger, carefully pry up the motherboard to remove it.
Sonuç
Andrew S
15.539 İtibar
8 adet Kılavuz yazıldı
2Kılavuz Yorumları
do you know of anyone that can fix these items
Rick MacDonald - Yanıt Paylaş
anyone out there fix these items
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 48
Her zaman: 1,242
