Ana içeriğe geç
DigiLand DL1010Q Battery Replacement
Neye ihtiyacın var
    1. DigiLand DL1010Q Battery Replacement, Rear Case: adım 1, 1 resimden 1.
      • With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
      • Before disassembling your device, be sure it is powered off.
      FixBot'a Sor
      Yorum Ekle
    2. DigiLand DL1010Q Battery Replacement: adım 2, 2 resimden 1. DigiLand DL1010Q Battery Replacement: adım 2, 2 resimden 2.
      • Using a plastic opening tool, begin softly prying open device by first inserting it in between the front and back panels.
      • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
      FixBot'a Sor
      Yorum Ekle
    3. DigiLand DL1010Q Battery Replacement: adım 3, 1 resimden 1.
      • Carefully lift back panel away from the body of the device.
      • Speaker wires are connected to both the front and back panel.
      FixBot'a Sor
      Yorum Ekle
    1. DigiLand DL1010Q Battery Replacement, Battery: adım 4, 2 resimden 1. DigiLand DL1010Q Battery Replacement, Battery: adım 4, 2 resimden 2.
      • Desolder positive and negative, red and black, wires from the mother board that are connected to the battery.
      • The soldering tool is hot, and will burn. For how to use a soldering tool follow the How to Solder Guide
      FixBot'a Sor
      Yorum Ekle
    2. DigiLand DL1010Q Battery Replacement: adım 5, 2 resimden 1. DigiLand DL1010Q Battery Replacement: adım 5, 2 resimden 2.
      • Using a metal spudger tool, wedge between battery and metal screen.
      • Follow the edge of the battery to loosen the glue.
      FixBot'a Sor
      Yorum Ekle
    3. DigiLand DL1010Q Battery Replacement: adım 6, 2 resimden 1. DigiLand DL1010Q Battery Replacement: adım 6, 2 resimden 2.
      • Once the glue is loosened, you should be able to pry off the battery from the screen.
      • Using your hands, pull up on the battery to pull battery off.
      • Pulling on the battery causes you to bend the battery. Bending the battery could cause it to break open. Battery fumes are toxic and unsafe.
      • The battery will be completely disconnected and you can set the battery aside in a safe place.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
3Kılavuz Yorumları
the replacemet has 3 wires .where go the 3 wire?
javier perez - Yanıt Paylaş
were can i buy a new  bettery
Theresa - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 21
Her zaman: 5,014
