Giriş
To replace the battery you will need a sharp edged tool, be sure to be careful. The glue on the battery is sticky and hard to get off.
Neye ihtiyacın var
With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
Desolder positive and negative, red and black, wires from the mother board that are connected to the battery.
Bir başkası bu kılavuzu tamamladı.
3 Yorum
the replacemet has 3 wires .where go the 3 wire?
