Ana içeriğe geç
DigiLand DL700D Battery Replacement
Neye ihtiyacın var
  1. DigiLand DL700D Battery Replacement, Battery: adım 1, 3 resimden 1. DigiLand DL700D Battery Replacement, Battery: adım 1, 3 resimden 2. DigiLand DL700D Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the device's back cover using the plastic opening tool.
  2. DigiLand DL700D Battery Replacement: adım 2, 3 resimden 1. DigiLand DL700D Battery Replacement: adım 2, 3 resimden 2. DigiLand DL700D Battery Replacement: adım 2, 3 resimden 3.
    • Remove the three pieces of adhesive placed over the edges of the battery.
  3. DigiLand DL700D Battery Replacement: adım 3, 1 resimden 1.
    • Remove the wifi antenna from the bottom of the battery.
  4. DigiLand DL700D Battery Replacement: adım 4, 3 resimden 1. DigiLand DL700D Battery Replacement: adım 4, 3 resimden 2. DigiLand DL700D Battery Replacement: adım 4, 3 resimden 3.
    • Heat up the soldering iron, proceed to desolder and remove the battery connections.
  5. DigiLand DL700D Battery Replacement: adım 5, 3 resimden 1. DigiLand DL700D Battery Replacement: adım 5, 3 resimden 2. DigiLand DL700D Battery Replacement: adım 5, 3 resimden 3.
    • Remove the battery from the casing using a nylon spudger.
    • Be careful not to puncture the battery casing.
    • Carefully peel the battery free from the casing.
Sonuç
To reassemble your device, follow instructions in the reverse order. Apply new Kapton Tape and apply extra solder as needed.
Justin Edwards
241 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G4, Harley Spring 2018 IUPUI, Team S3-G4, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S3G4
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 8
Her zaman: 341
