Ana içeriğe geç
DigiTech RP70 LED Light Replacement
Neye ihtiyacın var
    1. DigiTech RP70  LED Light Replacement, Motherboard: adım 1, 2 resimden 1. DigiTech RP70  LED Light Replacement, Motherboard: adım 1, 2 resimden 2.
      • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
      • Remove the four 8mm Phillips #0 screws located on the back panel.
      FixBot'a Sor
      Yorum Ekle
    2. DigiTech RP70  LED Light Replacement: adım 2, 2 resimden 1. DigiTech RP70  LED Light Replacement: adım 2, 2 resimden 2.
      • Remove the back panel to expose the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. DigiTech RP70  LED Light Replacement: adım 3, 1 resimden 1.
      • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. DigiTech RP70  LED Light Replacement: adım 4, 1 resimden 1.
      • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
      FixBot'a Sor
      Yorum Ekle
    1. DigiTech RP70  LED Light Replacement, LED Light: adım 5, 1 resimden 1.
      • Desolder the back of the motherboard where the LED light is located.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 12
Her zaman: 555
