Ana içeriğe geç
DigiTech RP70 DC Power Connector Replacement
Neye ihtiyacın var
  1. DigiTech RP70 DC Power Connector Replacement, Motherboard: adım 1, 2 resimden 1. DigiTech RP70 DC Power Connector Replacement, Motherboard: adım 1, 2 resimden 2.
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. DigiTech RP70 DC Power Connector Replacement: adım 2, 2 resimden 1. DigiTech RP70 DC Power Connector Replacement: adım 2, 2 resimden 2.
    • Remove the back panel to expose the motherboard.
  3. DigiTech RP70 DC Power Connector Replacement: adım 3, 1 resimden 1.
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. DigiTech RP70 DC Power Connector Replacement: adım 4, 1 resimden 1.
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
  5. DigiTech RP70 DC Power Connector Replacement, DC Power Connector: adım 5, 1 resimden 1.
    • Desolder the back of the motherboard where the power connector is located.
Sonuç
1Rehber Yorum
Later? I cant see to other
ISAAC SALAZAR - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 439
